Results 1 to 10 of 16
Thread: PIDs for E38 & T43
    Nov 2006
    Default PIDs for E38 & T43
    Can I get a couple pid lists for these two controllers?
    2009 Holden Commodore w/left-hand drive option.
    LC-1 WBO2
    swingtan
    Guest
    Depends on what you want to log.......
    Here's what I currently log via BBL.
    Code:
    ECM,  IAT
    ECM,  AAT
    ECM,  SPARKADV
    ECM,  MAP
    ECM,  VSS
    ECM,  ETCTP
    ECM,  APP
    ECM,  ECT,             ,                                         -10:110:9:10:0
    ECM,  INVLVTMP_M
    ECM,  KNKRET,          ,                                         0.0:1.0:131:10:0
    ECM,  OCTSCL_M
    ECM,  MAFFREQ2
    ECM,  AIRPERSEC
    ECM,  MAF
    ECM,  APCYL_M
    ECM,  RPM,             ,                                         0:6200:66:10:0
    ECM,  AFRATIO_M
    ECM,  INJPWB1
    ECM,  INJPWB2
    ECM,  SHRTFT1
    ECM,  SHRTFT2
    ECM,  HO2S11
    ECM,  HO2S12
    ECM,  BRKR
    CLC,  BEN1_E38
    Also the serial PIDs for the Techedge WB.
    It's been a while since I seriously logged a T43 though. If we were talking T42, then I use the following...
    Code:
    TCM,  ACCEP
    TCM,  RPM
    TCM,  TBASEPAT
    TCM,  VSS
    TCM,  GEAR
    TCM,  BRKR
    TCM,  SHIFTLAST
    TCM,  IAT
    TCM,  ECT
    TCM,  TFT
    TCM,  TRQENG_C
    -,    DYNTRQ
    TCM,  TCCP
    TCM,  TCCS
    TCM,  SHIFT34
    TCM,  SHIFT23
    TCM,  SHIFT12
    -,    DYNPWR
    TCM,  ADAPTCELL
    TCM,  ADAPTSHIFT
    TCM,  TURBINE
    TCM,  TFMDES
    TCM,  TFMCUR
    TCM,  TCSLIP
    TCM,  TCCSLIP
    TCM,  TFMDC
    Simon
    Nov 2006
    Thanks.
    Nice car Simon, I always liked it.
    LC-1 WBO2
    Nov 2006
    Is there a trick to reading the PCM?
    I am getting bootloader rejected error.
    The previous owner may have locked it because there is a CAI installed and
    looking around other forums I find CAI & some type of lousy handheld flasher is popular with these vehicles.
    The TCM read with no problems.
    LC-1 WBO2
    What car did you get...?
    swingtan
    Guest
    I take it you selected the E38 pid list prior to reading ?
    Nov 2006
    I selected the E38 controller, if that's what you meant.
    The supported vehicle list shows Pontiac G8 has E38.
    I know some vehicles have issue reading/writing unless other devices are removed from the CAN bus.
    2009 Pontiac G8
    LC-1 WBO2
    Nov 2006
    I need an E38 with stock OS & calz for this car while I have the PCM unlocked.
    The closer to AZ the better.
    LC-1 WBO2
    swingtan
    Guest
    I have a stock 2009 Holden SS-V tune.... but it's about as far from AZ as you are going to get. Will that work for you ?
    Simon
    Edit: I should note that this is for an AFM / DOD motor, so it's an auto.
    I know TIS says to remove fuses on some cars, but it's not necessary with EFILive on CAN vehicles.
  1. E35 IAT & IAT2 PIDs.
    By Cougar281 in forum Diesel
    Last Post: August 9th, 2010, 01:11 PM
  2. Looking for STFT & other pids
    By Chalky in forum FlashScan V2 BB Logging
    Last Post: May 21st, 2008, 10:21 AM
