Page 2 of 9 FirstFirst 1234 ... LastLast
Results 11 to 20 of 84
Thread: Calc.MAFT: correcting VE and calculating MAF (in single log) --> reverse of Calc.VET
    swingtan
    Guest
    A quick note for the E38....
    I tried this some time ago with the E38, but we are missing the DYNAIRTEMP PID. I found you can get get very close with the following though....
    "({SAE.RPM}/120)*({E38.APCYL_DMA}*8)"
    This uses the ECM's existing Air/Cylinder figure which should factor in the air temp corrections. I'd think that the LS1 controller would be able to use a similar equation.
    Simon.
    I use it quite a lot to cross reference the VE table and the MAF and it helps point out things like reverberation.
    Simon.
    Simon, good point.
    E38.APCYL_DMA is the ECM/PCM computation of VE[g*K/kPa]/DAT[K]*MAP[kPa], and probably includes some internal adjustments/corrections.
    LS1B equivalents of this are GM.DYNCYLAIR and GM.DYNCYLAIR_DMA.
    LS1B also computes the equivalent airflow GM.DYNAIR, we could simply use this diectly, i.e. MAF = {GM.DYNAIR}.
    We should probably experimentally log/calculate the following to see how they compare:
    MAF1 = {GM.VETABLE_DMA.VE}/{CALC.DAT.K}*{SAE.MAP.kPa}*{SAE.RPM}/15
    MAF2 = {GM.DYNCYLAIR_DMA}*{SAE.RPM}/15
    MAF3 = {GM.DYNAIR}
    Here's a calc_pids.txt file we can use to compare MAF1, MAF2, MAF3.
    Shawn,
    {GM.DYNAIRTMP_DMA.C}+273.15 now appears in too many calcpids, so it may be simpler to give it its own calc pid, see CLC-00-273.
    It seems that possibly the PCM may be including temperature adjustment/correction/modeling in these...
    swingtan
    Guest
    Oh, I just thought of something! If E38.APCYL_DMA is "VE[g*K/kPa]/DAT[K]*MAP[kPa]", then we should be able to reverse the equation to create a calc-pid for the actual charge temp.
    RE: comparing the tables, I've done this in the E38....
    Green=MAF Airflow.
    Turquoise=ECM Calculated Airflow (AIRPERSEC)
    Purple=Calc PID based off DYNCYLAIR and RPM.
    A closeup of the airflow after the first big throttle close.
    Again, it's E38 based but the theory should hold true for LS1 as well.
    Simon.
    Simon, that's a very good observation, good insight
    Jul 2008
    So the infamous SD Vs MAF Airflow Correction could be expressed (g/cyl) as:
    GM.DYNCYLAIR.DMA-GM.CYLAIR.DMA/GM.DYNCYLAIR.DMA X 100 (%)...???
  9. #19
    Lifetime Member Mr. P.'s Avatar
    May 2007
    There was no working or tuning on the truck last night - we had several rounds of quarter to ping-pong sized hail last night and thunderstorms here in Plano. :( So no log file to contribute this morning, sorry.
    Mr. P.
    2003 Silverado SS, with Novi-1500 "CAI mod"
    EFILive V 7.5 COS-3 (OLSD, for now!)
  10. #20
    (GM.DYNCYLAIR.DMA-GM.CYLAIR.DMA)/GM.DYNCYLAIR.DMA X 100 (%)...???
    Yes, correct (corrects MAF table from VE table):
    (GM.DYNCYLAIR.DMA-GM.CYLAIR.DMA) /GM.DYNCYLAIR.DMA *100[%]
    Or like this (corrects VE from MAF table):
    (GM.CYLAIR.DMA-GM.DYNCYLAIR.DMA) /GM.CYLAIR.DMA *100[%]
    Those would give the correction errors percentages.
    Shawn, good observation... this presents a very interesting shortcut.
  1. Calc.VET: correcting MAF and calculating VE (in single log)
    Last Post: February 20th, 2023, 04:55 AM
  2. CALC VET Summary Notes
    Last Post: August 28th, 2014, 07:49 PM
  3. CALC. VE Table help
    By nchristian in forum Gen III V8 Specific
    Last Post: January 28th, 2011, 09:18 AM
  4. RPM Threshold for Airflow Calc {B0120}:
    By Mark300 in forum E37, E38 & E67 PFI ECM's
    Last Post: December 2nd, 2009, 01:40 PM
  5. Startup Friction Airflow Correction table?
    By jnorris in forum General (Petrol, Gas, Ethanol)
    Last Post: November 10th, 2005, 05:01 PM
