Results 11 to 20 of 39
Thread: E38 G0901 Table for Fans settings
    Lifetime Member Chalky's Avatar
    Sep 2003
    Will try it tomorrow!
    2015 Z06 A8
    Sep 2003
    So do you see it now?
    Come to think of it, it's possible not all E67 OS's where completed.
    Hooked up V2. Still no B9904.
    2015 Z06 A8
    Can you please Email you .tun file to support@efilive.com
    Do you want me to do that too for the OS I posted above?
    May 2009
    I am trying to apply the Operating Patch B9904 to allow lowering the fan turn on temp. I have applied the patch however cannot seem to find the table for altering the fan temp (G0901?) The operating system is 12638778and calibration is 12636660. What am I missing?
    Aug 2010
    That is a GMPP OS (12638778), and the fan controls have never been defined. Post your tune, and I can setup the fan (or fans) for you.
    May 2009
    Roy_Rokosh_ERod_LS3_6October2014_Fan_Patch_Read.tun
    That would be incredible, thank you very much.
    Cal file attached.
    Is adding tables a difficult thing to do.
    Eldon
    Aug 2010
    Not sure what you are working on, or what would be optimal for this project. If memory serves, GMPP wiring harnesses are setup for a single electric fan. You could add a wire to control another fan (low & high) if you wish. No problem to setup the tune for two fans.
    You have applied the Cooling Fan Patch - when do you want the fan to come on ? The earlier than OEM options are 172, 177, 183, or 188 F.
    Just let me know ...
    Regards,
    Taz
  9. #19
    May 2009
    Hi Taz
    The car is a 50 Merc kit (fibreglass car). The owner feels it is running too hot, upwards of 220.
    It would be great if you could have the fan come on at 183. It has a 180 stat in it so the fan should come on once the water is flowing. Did I miss a location to be able to modify the temp setting.
    Please set it up for a second fan as well, thanks.
    Sincerely
    Eldon
  10. #20
    Aug 2010
    Hello Eldon,
    That is an awesome set of wheels !!!
    No sir, you did not miss anything - the fan parameters are missing in the software for that GMPP OS.
    Try the attached tune. The Low Fan should come on at 183F, and turn off again at 172F (or never !). The High Fan should come on at 194F, and turn off again at 188F.
    Taz
  1. GEN IV E38 Holden Commodore Cooling Fans
    By CRFaig in forum Gen IV V8 Specific
    Last Post: July 12th, 2011, 09:41 AM
  2. E38 Cooling fans question
    By Chalky in forum E37, E38 & E67 PFI ECM's
    Last Post: September 1st, 2009, 01:11 PM
  3. E38 Fans patch not being applied
    By Highlander in forum Custom Operating Systems
    Last Post: November 7th, 2008, 09:50 AM
  4. Fan settings E38
    By eboggs_jkvl in forum E37, E38 & E67 PFI ECM's
    Last Post: August 14th, 2008, 11:15 PM
