Page 2 of 8 FirstFirst 1234 ... LastLast
Results 11 to 20 of 72
Thread: Public Release June 03, 2011
    Quote Originally Posted by L31Sleeper View Post
    Do you have to buy the cummins tuning option to edit cummins files ?
    No, you only need a license to flash them. You can also read out a Cummins tune without requiring a license.
    Junior Member Jedi_Jr's Avatar
    Jul 2010
    04 P10 OS 12597031 CAL 12576872 Cal Def file 12597031.calz
    B0642 Misfire coolant enable is set to 125DEG C and that is 257 DEG F which would indicate that it never tests for misfire, as the engine never gets to 257. Is it supposed to be in DEG F?
    May 2010
    7.5 won't open at all with the v2 plugged in , ver 8.1 works fine, any ideas ? Thanks
    Quote Originally Posted by vern View Post
    Hi Vern,
    Did you update V7 to build 164...?
    Did you update V8 to build 155 and then flash your V2 with firmware 2.07.11...?
    May 2010
    Yes, i installed all the new updates, i used a different computer with build139 and it opens ok ?
    Oct 2004
    Can you please try this suggestion from THIS THREAD? It basically gets you to install the old driver version to see if that resolves the issue. Please let us know the results.
    Andrew
    EFILive Crew
    May 2010
    Thank you! that fixed it
    Dec 2006
    Well I hope there isn't something obvious I missed but I just downloaded the latest updates of 7 & 8 and 8 does not recognize my FS2. It does not display boot block and firware vesion and says no response. I tried both with and without dead poll. 7 seems to see the FS and all my licenses, thank God. ???
    8.7 @ 84 (1/8 mile) bolt-ons
  9. #19
    Quote Originally Posted by Boost View Post
    There may be an issue with the installer not updating some files in the V8 install folder, we're still investigating.
    To force the installer to install the latest files, delete the entire V8 installation folder
    C:\Program Files\EFILive\V8 (or C:\Program Files (x86)\EFILive\V8 on 64 bit Windows) and then re-run the installation.
  10. #20
    Lifetime Member Rich Z's Avatar
    I'm trying to do the procedure on the page "Upgrading FlashScan & AutoCal Bootblock and Firmware Versions" but not having any luck. I'm a complete noob at this, so bear with me, please.
    I've gotten to step 4 where I'm supposed to be seeing an image of my FlashScan V2 in the FlashScan and AutoCal Device Settings screen in the bottom right corner, but I see no such thing. All I see are a row of icons representing Open, Save, Read, Program, and Close. There is an icon of the V2 in the lower right hand corner of my desktop, but when I click on that I get an error message saying "No device connected". Now I can load up v7.5 and see the V2 just fine, showing my my license numbers, but in the Scan and Tune V8, it appears that it does not recognize my V2 at all.
    I'm assuming I'm just missing something obvious because this is the first time I have run this procedure. But sure would be nice to have a little "hand holding" to walk me through...
    Oh, I'm running Win XP on my laptop, btw.
    CorvetteFlorida.com
    2002 Corvette Z06
    427 RHS block built by LME
    STS rear mounted twin turbos
    It nearly died on the operating table, but I'm bringing her back.
  1. Official Public Release - Mar 20, 2011
    Last Post: April 2nd, 2011, 10:02 AM
  2. January 31st 2011 pre-release (Updated Feb 03, 2011)
    Last Post: February 24th, 2011, 06:14 PM
  3. Official Public Release - August 16,2010
    Last Post: October 8th, 2010, 05:57 PM
