Well, your HO2xx looked a lot better..but there are still some patterns I would not call normal. At this point your O2 sensors may be working, but may be responding to the fuel delivery issue that is still evident.
Your LTFTS still swing more than normal. On Log 0011:
Bank 1: -3.9 to +11.7.
Bank 2: -8.6 to +9.4
That an unsymmetrical swing from Bank 1 to Bank 2..and the actual variance seems out of norm.
I would still concentrate on the fuel pump/fuel delivery issue. Without 58 psi I don't think you will have a normal injector flow. You are overall still lean (Trim-wise) and do not have the correct fuel pressure for an LS1 engine..
