If the MAF pegs at maximum, then that is the value used... stays in MAF'd mode.
Alright- just finished installing a PLX WB sensor. When testing the gauge the truck seems to be running way lean so I am going to run through the calc ve and see what I learn.
I am using a V2.
So far I am not getting a reading off the PLX analog out....still working on it
Okay- I was using the wrong PID- i picked the one for PLX and did not select the ext.ADX pid.
The PLX has serial comms output... are you using this to read the AFR/lambda into V2...?
Yes- I am using it to provide afr data to the log.
I do not think I logged the correct info though as I only got zeros in the map- see attached.
Log_WB Working 0002.efiCustom Base_EFIMuscle_0008.tun
Alright I got it now- I had accidently selected % when my tune runs with kpa. I am going to get a chance tomorrow to take it on the road and get a log under load.
I do have one question- so far the WB has not sat still at all- it is constantly swinging from 12 to 20 (mostly from 16 to 20). Is this common or is it possible I have an intake leak or some other issue? The tune does not appear to have that rough of a curve in it.
Thanks again for everyones help in guiding me along.
G
This is where the newbie would be applied.......I thought analog was good enough to perform a calc.ve- do I need to make the WB feed the pcm in order to be usefull?
