Results 1 to 8 of 8
Thread: 80E Irregular Lockup in 4th grear.
    Junior Member TIM Z's Avatar
    Apr 2009
    Default 80E Irregular Lockup in 4th grear.
    I am having trouble tuning my 4th gear TCC lockup.
    Its very irregular. Vehicle is a 2000 silverado with 6.0 LQ4/TVS 1900 blower and a 2004 4L80E with a P I 2600 Multi disc stall.
    It will lock , converter is brand new, did the segment swap, shifts great.
    I read a post by a guy having the same problem, he has hptuners, they told him to " make the "Performance" Apply/Release tcc lockup tables the same as Normal and cruise.
    Set p0300 to 3- No error reported.
    You also need to go to Trans Diag > TCC Set Max Slip Rpm to 3000."
    I made all my apply and realese table the same mph, still have irregular lockup.
    I also looked for p0300 in the transmission DTC codes but couldnt find it???
    Any help on what to change in my tables would be appreciated, its driving me nutz not having regular lockup!!!
    2007 CCSB 4x4 Duramax LBZ
    Merchant built STG III Allison/ P. I. Race Converter
    lots more mods
    EFI Live V2 /DSP5 / Diesel Addiction Custom Tuning
    2000 Silverado ECSB
    6.0 LQ4 , TVS 1900 , Comp 226-224 114+4
    Long tubes/Duals.
    Built 4L80E trans/ P.I. 2600 Vigilante converter
    EFI LIVE Tuning.
    Check that the brake switch is not intermittent.
    Apr 2009
    Thank you Joe, i have wandered bout that, i find myself using my foot to pull back on the brake pedal to make sure its not sticking, any other way to tell if its bad?? Or is it just a good idea to replace it??
    Never had any lockup issues with my 65E.
    lots more mods
    2000 Silverado ECSB
    Long tubes/Duals.
    EFI LIVE Tuning.
    One of the TSTATE pids shows the state of the brake switch;
    and, also, another TSTATE pid shows the reason why the TCC was unlocked.
    Apr 2009
    There are TSTATEs listed in my PID list with No description, Which ones are they?
    I see # 00 thru 12 and 13 14 15 16 17 18 52 58 59 60 61 64 67.
    Sorry but i dont know what each of these does. Thanks!!
    lots more mods
    2000 Silverado ECSB
    Long tubes/Duals.
    EFI LIVE Tuning.
    If you do rightclick->More Info on each pid you will see a description.
    TSTATE00-12 are for the 4L60E/4L80E.
    TSTATE00 indicates brake switch position.
    TSTATE09-10 indicate TCC off reason.
    Apr 2009
    Joe you are so awesome! Thankyou very much for schooling me on this , i appreciate it!!!
    lots more mods
    2000 Silverado ECSB
    Long tubes/Duals.
    EFI LIVE Tuning.
    No worries thanks.
  1. Knocking in 4th
    By white01ss in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: June 19th, 2008, 03:57 AM
  2. Help with 80E shift points
    Last Post: May 20th, 2008, 03:08 PM
  3. TCC lockup quicker w/80E
    By nonnieselman in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: April 11th, 2008, 07:06 AM
  4. 2nd and 4th only again
    By insane04 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: January 8th, 2008, 06:16 PM
  5. Need help building 80E file for OS 12216125
    By 1SlowHoe in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: July 15th, 2007, 12:51 PM
