Page 2 of 13 FirstFirst 123412 ... LastLast
Results 11 to 20 of 123
Thread: problem with calc.vet
    Of the VE map and the MAF SELBEN map.
    Quote Originally Posted by loganlewis View Post
    I referred to it as you said and got it to show the data. It feels better. Can this be done for the whole tables or just under 4000rpm? I have an aem uego wideband hooked up and I have a aem picks and have to activate the ad1 external 0-1 pod and it shows afr. My question is the calc.vet pids show an external lamba cable but I don't know what good it does me as it doesn't show the voltage like the aem pid does. Any ideas taz?
    Without lambda then you cannot apply calc.vet for open loop since you will not know that the correction is.
    Jun 2011
    Well I'm not sure how to do screen shots or what u want them of? and I did everything under 4000rpms and it drives alot better and before I started the afr cruising would jump all over the place now it hangs between 14.3-15.0 and is smooth. The lambda thing does not show anything that's what I was wondering about as well. Is it because I use the aem 0-5v wire and hook it into the ad1 port on the v2. And now that the 4000 and under tuning is done, I have no positive fuel trims that I saw. And the things I changed to tune (change u2 switchpoints to 450, change dfco, and change other table from 4000 to 400), do they need to be changed back now that I'm done tuning for a few days or change them back?
    Like I said I really appreciate the help. Taz helped me in the beginning maybe you can help me finish!
    Jul 2008
    LL:
    Are you just using LTFT corrections or correction from your wideband also.
    We need screenshots to verify the results. Thanks..
    Jun 2011
    Just ltft that's why I stayed under 4000rpm I'm not sure how to incorporate my wideband even though I have te calc pids for it and log it and the logs show my afr the whole time
    Jul 2008
    Can you at least post up your calc_pids.txt file?
    Keeping the Rpms under 4000 Rpm will not necessarily keep you in closed-loop. So you are not getting as accurate of a tune that way. It only takes 34% TPS at 4000 RPM's to initiate PE.
    Its totally up to you. People who post up, but won't share their results helps no one. There may be a dozen other readers who could benefit from your helping others out.
    But, if you are totally happy with your Tune..enjoy your ride..
    Jun 2011
    I'll have to get screen shots tomorrow but just wondering how I'm going to use my wideband to do 4000+rpms with pe disabled. Like I said I searched and found a guy who posted the pids to use for an aem gauge and I select the pid aem wbo2 afr and external voltage ad1 pid and it all works. Need to figure out how to incorporate the aem afr pid into calc.vet I guess. Screen shots will be posted tomorrow if I figure out how
    Jul 2008
    I suspect you are not using the correct calc_pids.txt file.
    Taz is an experienced Tuner who disables PE, but incorporates other methods to tune.
    CALC.VET allows both closed-loop and PE mode simultaneously.
    Let us know if we can help..
  9. #19
    Jun 2011
    It's not that I don't want to post it up I am in bed I'm replying back on here off my phone. So tomorro I'll get that stuff up. How do you take a screenshot
  10. #20
    Jul 2008
    ..http://forum.efilive.com/showthread....ting+an+inamge..
  1. Replies: 83
    Last Post: September 5th, 2023, 12:30 PM
  2. CALC VET Summary Notes
    Last Post: August 28th, 2014, 07:49 PM
  3. Replies: 4
    Last Post: June 3rd, 2011, 10:07 AM
  4. 98 F-body pcm in a 97 Vet
    By TurboVet in forum Gen III V8 Specific
    Last Post: September 20th, 2007, 06:08 AM
