Page 4 of 11 FirstFirst ... 23456 ... LastLast
Results 31 to 40 of 106
Thread: Public Release Update June 24, 2011
  1. #31
    Nov 2006
    $0194 usually means "file system full".
    It may also be the case now that trying to select ALL controllers for both flashing and scanning will not fit into the config area.
    So you may need to un-check some controllers that you won't be using.
    But definitely do what Joe suggested and format the config file system as that will remove any old/unused files and will free up some space.
    Hint: the DTC description files take up the most room so by un-checking them (on the DTC tab page) you can save a lot of space.
    Except that you won't be able to display DTC descriptions on FlashScan's screen.
    You should never select the DTC descriptions for AutoCal devices - since AutoCal cannot display DTC descriptions.
    I got $0194 write failure while programming just E38 config files & pids.
    Probably no biggie tho.
    LC-1 WBO2
  2. #32
    There may be other files already on the device that are taking up space.
    Using EFILive_Explorer, how much space is shown as used/free when you click the [Properties] button on the [Config] tab page?
    However, $0194 is a "general write failure", so if it is not occurring because of file system full then there may be a fault with the flash memory.
    It might be useful to run a flash memory check.
    You can do that by selecting F4: Options -> F4: Self Tests -> F4 (hidden option).
    Press Ok to clear the message about needing a second FlashScan device.
    Then select option "2.ROM" to test the flash memory.
    Note: You'll need to reformat the [Config] file system after the test because the test completely erases the Config file system.
  3. #33
    May 2009
    E35B codes P2033 and p0546 showing up on V7 scantool as from the TCM?? codes are turned off in ECM tune (DPF delete). Don't seem to be causing any issues, maybe phantom codes similar to B2911 in cummins ECM?
  4. #34
    Nov 2009
    I will send you the file with the bad checksum paul. I was able to script the tune and load it to the same OS and had no issue. The problem i assume was editiing with the old software and the new upload, oddly it is the only file that is acting as though it somehow corrupted. Tahnks, i will send it on to you
    -Kory
    http://www.PPEI.com/
  5. #35
    Jul 2010
    You can manually download the USB_Manager.exe program here:
    http://www.efilive.com/index.php?opt...=48&Itemid=133
    Scroll down to the utilities section.
    Paul,
    I manually downloaded the USB Driver, even opened it up as an Admin, and I'm still getting an error. This is what I get when I click on the "Install USB V2.02.04"
    "File not found: C:\Program
    Files\EFILive\Drivers\EFILive\Win-2K\i386\dpinst.exe."
    I'm lost.
  6. #36
    May 2009
    CANNOT FULL FLASH AL5 ALLISON TCM. After it erased tcm it then hesitated and repeatedly said retrying previous block, after five minutes i stopped it. now when i try again it counts to 120 erasing flash memory then says flash failed. i have removed and reinstalled and am using old USB drivers
  7. #37
    Quote Originally Posted by RAZRS EDGE View Post
    Paul,
    I'm lost.
    Did you install V7 software in the default location...?
  8. #38
    Apr 2008
    Formating did solve the $0194 error.
  9. #39
    Apr 2008
    Have you read through this tutorial?
    http://download.efilive.com/Tutorial...20Tutorial.pdf
    There are a few things about creating/saving dash boards and dash pages that can get confusing. The document attempts to explain how it works.
    Yes I have. The issue is happening with existing dash boards that I have been using for years. I have set what dash board I want to open at startup in the options but it will not open comes up as a blank screen if I open them once the scan tool is open they are ok.
  10. #40
    Apr 2008
    Issues continue with the latest update. The biggest problem issue is the scan tool freezing when disconnecting from a Cummins ECU. It does not freeze with LS1B ECU. I have to disconnect the USB cord to get the Scan Tool to unfreeze. I had left the USB connected and froze for 15 minutes before pulling the plug. It freezes every time I disconnect from Cummins ECU. Also I am now getting an error 1400 when I close the Tune Tool. The error pops up 5 times each time I close the tune tool.
  1. Public Release June 03, 2011
    Last Post: July 9th, 2011, 07:59 AM
  2. Public Release Update June 06, 2011
    Last Post: June 20th, 2011, 07:12 AM
  3. Official Public Release - Mar 20, 2011
    Last Post: April 2nd, 2011, 10:02 AM
  4. January 31st 2011 pre-release (Updated Feb 03, 2011)
    Last Post: February 24th, 2011, 06:14 PM
