Page 32 of 75 FirstFirst ... 22303132333442 ... LastLast
Results 311 to 320 of 741
Thread: Calc.VET: correcting MAF and calculating VE (in single log)
  1. #311
    Sep 2008
    Bummer.
    On m VET average map I have numbers as high as 2.44 and 2.47, and numerous cells over 2.0 in the upper rpms. Could it really be that lean? I know my wideband has read 17.x a few times at idle.
    I just want to make sure I've got thing correct before I start my copy, and pasteing.
    2007 TBSS-All stock
    2001 WS6 TA-Stockish, custom paint, LS7 clutch, spray, 6 point rollbar.
    1998 TA- Not much stock, 408, t350, spray, cage, fastest LSX in Alaska, 9.755@136 (so far)drag radial street car, driven, never trailered.
  2. #312
    Jul 2008
    Those numbers indicate your VE Table units are in g*k/kPa. There is no direct unit correlation between that and wideband AFR readings. I.E., it will be your BENS that indicate whether your lean or rich.
    Are your SELBENS ~ 1.00 from 1500-12,000 Hz?
    If cammed, Idle occasionally will go from ~14-17 AFR at Idle. Any more and yes that would be lean.
    I suppose posting a Tune & Log would be better at this point. I'm not sure how to advise you whether your Tune is good to go yet....
  3. #313
    Frozen WS6,
    try this: attach the pics directly in the post, i.e. in post #308 above, delete the url's, then click Manage Attachments and upload the files...
    see post #2 here: Hosting-an-Image
  4. #314
    What are your mods...?
  5. #315
    Sep 2008
    Mods: 408 cid iron block, fast 92, 92 tb, ls6 ported+polished heads 2.08/1.60 valves, 11.7:1 compression, cam .248/.254 .622/.614 @114, kooks 1 7/8" stepped to 2" headers w/3.5" collectors, underdrive pulley.
    340 intank walbro pump, highflow fuel rails, -8 fuel lines, 42.5lb fast injectors.
    It is on spray but I'm working the NA tune right now.
Name:	98 TA CALCVET DATA2.PNG
ID:	11237Click image for larger version.
Name:	98 TA CALCVET DATA1.PNG
    2007 TBSS-All stock
  6. #316
    Jul 2008
    Frozen:
    On your SELBEN Map..if you could change 'Cell Count' to 'Average Value'..that will allow us to see the actual data..
    I see you had a max of 11.9 degrees of KR. Whats going on there?
  7. #317
    Sep 2008
    I usually get knock at low rpms, mostly idle. But that was the first time I've seen so much. I think it's my coil. So I'm going to swap one off of my WS6 and see if it clears up. Here are a couple of other scans of the knock area and the upper rpms. Also I switched the Selben to averages.
Name:	98 TA CALCVET DASH.PNG
ID:	11241Click image for larger version.
Name:	98 TA CALCVET DASH2.PNG
ID:	11242Click image for larger version.
Name:	98 TA CALCVET SELBEN AVE.PNG
    2007 TBSS-All stock
  8. #318
    Your scantool still has MAP in psi units (you want kPa)...
    on PIDs tab: on SAE.MAP do rightclick->Metric.
    Also: for maps A and B, in map properties goto each tab Data, Row, Col and checkmark Show Units and save the map.
  9. #319
    Also, I don't see the pid CALC.VEN... you're using an older calc_pids.txt file.
  10. #320
    Jul 2008
    Also, Frozen is your SELBEN Table plotting vs MAF frequency or RPM?
    At some point it might be easier to just attach the Log with all the MAPS you used.
    I have a feeling their are some issues here that might not allow you to use this log..
  1. Please explain table A0007 TPS VE TABLE cos5
    Last Post: March 18th, 2008, 06:26 PM
  2. OLFA table vs. Custom OS A0008 table
  3. Table Names vs Table Number
    By lplott in forum Custom Operating Systems
    Last Post: May 17th, 2006, 05:14 AM
  4. Main VE Table ?, Logged data vs VE Table
    By dbaxter_ss in forum Tips and tricks
    Last Post: December 26th, 2004, 03:36 PM
