Results 1 to 9 of 9
Thread: Anyone else running COS on high boost motor?
    Redline Motorsports
    Guest
    Default Anyone else running COS on high boost motor?
    Still struggling with this custom OS 2/3bar setup. Whatever it is will end up being real stupid I'm sure but in the mean time its driving me nuts!
    Just interested in hearing from others that are using 2/3 bar function on high strung motors.
    Howard
    Lifetime Member MN C5's Avatar
    Mar 2005
    I've got mine done, but don't have the truck running right now. I've tuned a couple of Radix/Maggy vehicles but only for 8-10lbs of boost. The added control really helped those vehicles.
    Should have the truck running in the next couple of weeks. I was running a 2 bar map without the custom OS and it worked well for me.
    Junior Member MCG's Avatar
    Jul 2005
    No problems here on several setups with the 2/3 bar MAPS. Take your time and triple check everything. One thing people forget is to rescale the MAP sensor. You can tell because it reads half of what you expect.
    Aug 2004
    i think im at 40 or so now "not counting the ones i give to the internet guys"
    EFILive Reseller kbracing96's Avatar
    Sep 2005
    My setups not to extreme, but I'm running COS 3 with a 2 bar and 10 lbs of boost on a turboed 4.8. Runs pretty good .
    Redline Motorsports
    Guest
    Quote Originally Posted by MCG
    Sore subject! Right Jess!
    I am still struggling with the MAP problems with this custom OS. There is a thread running in the general section that goes on about that.
    Lifetime Member mistermike's Avatar
    Dec 2003
    Quote Originally Posted by kbracing96
    About the same numbers here. Works very well, except for my unstable fuel pressure which is in the process of being redone.
    World's First Twin Screw Pontiac GTO
    2004 GTO. Blown H/C 408, stage 3 keyboard, billet tires
    2017 Chevy SS with dead hooker is spacious trunk
    2014 Chevy Cruze. MPG queen with my balls in spacious glove compartment.
    www.aussiemotive.com
    Redline Motorsports
    Guest
    Quote Originally Posted by wait4me
    Show off!
    HT
    Jun 2005
    I am running 15 psi with a 3 bar map and have had good luck with it. I am even running 96 lb injectors with 93 octane pumpgas!! I am hoping to turn the boost and timing up in spring!
    '71 chevelle
    Twin turbo ls1
    1000 HP 93 octane street car!
    96 lb injectors
  1. High RPM (3500-3900) boost issue... not reaching target??
    By GeneralTJI in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: July 20th, 2010, 05:58 PM
  2. motor swap
    By OrangeFlash05 in forum General (Petrol, Gas, Ethanol)
    Last Post: July 4th, 2009, 07:53 AM
  3. gen 1 motor with gen 3 ecu
    Last Post: January 14th, 2006, 01:27 AM
  4. 402 ci motor
    Last Post: November 25th, 2005, 09:38 AM
