Page 8 of 11 FirstFirst ... 678910 ... LastLast
Results 71 to 80 of 106
Thread: Public Release Update June 24, 2011
  1. #71
    Apr 2007
    done
  2. #72
    Quote Originally Posted by MSURacing View Post
    done
    I haven't received the file/email yet...
  3. #73
    Tuned all day with no problems!!!!!!!!!!!!!!!
  4. #74
    Apr 2007
    Got it working, something about the auto update didn't work. Thanks Paul for the timely support.
  5. #75
    Quote Originally Posted by cumminsDK View Post
    CANNOT FULL FLASH AL5 ALLISON TCM. After it erased tcm it then hesitated and repeatedly said retrying previous block, after five minutes i stopped it. now when i try again it counts to 120 erasing flash memory then says flash failed. i have removed and reinstalled and am using old USB drivers
    The AL5 full-flash problem has been identified and we're working on a fix. The fix should be available in the next update.
    I hope to have the update ready this weekend. But that depends on whether the PID/dashboard issues can be fixed as well.
  6. #76
    Junior Member dennisscars's Avatar
    Feb 2008
    I'm getting a Error 404 file not found so I did a manual install hoping maybe I was just a couple versions behind. Both manual installs where successful but still getting a error 404 when I try to check for new update. Search finds both files. I seem to remember this to be something easy but I can't remember what it is.
    Also can you move the Check for update a couple lines away from Uninstall so I don't click on it by mistake?
  7. #77
    Quote Originally Posted by dennisscars View Post
    The auto-update (i.e. the response to the "check fro new update") has been taken offline until we figure if it is causing problems with existing EFILive installations.
    We'll get it back up as soon as we've fixed it.
  8. #78
    Oct 2004
    For the benefit of all... We have disabled Auto Update presently due to an issue. Please download and install the full versions from our website. Also please ensure you update your FlashScan v2 device firmware. There is some more info in these knowledgebase articles that might help:
    - Software updates: http://support.efilive.com/kb_articl...5404-IJZV-0820
    - Firmware Updates: http://support.efilive.com/kb_articl...7243-SFGL-2949
    The order of the items in the EFILive (and other program groups) is alphabetical. So we don't have much control over that sorry.
    Regards,
    Andrew
    EFILive Crew
  9. #79
    Mar 2009
    HELP!!!!! since i have downloaded this update i tried to update the tune on a lly duramax and it locks the laptop up if i try to use V7.5 so i tried using V8 and when i did it erased the ecm just fine but when it gets to program it stops and give me an error that says no data received and starts the count down so now the truck is dead in the water does nothing at all when you hit the key lucky for me this is a friends truck so i let him borrow one of my trucks but this has got to be fixed NOW!
  10. #80
    Mar 2009
    i can also be reached at torquedieselllc@gmail.com i really need a solution for this asap and i get email to that address on my cell phone
  1. Public Release June 03, 2011
    Last Post: July 9th, 2011, 07:59 AM
  2. Public Release Update June 06, 2011
    Last Post: June 20th, 2011, 07:12 AM
  3. Official Public Release - Mar 20, 2011
    Last Post: April 2nd, 2011, 10:02 AM
  4. January 31st 2011 pre-release (Updated Feb 03, 2011)
    Last Post: February 24th, 2011, 06:14 PM
