Results 1 to 5 of 5
Thread: Modify PID
    May 2009
    Default Modify PID
    I would like to modify an existing PID calc to read my autometer.
    10 to 20 afr between 0 to 4 volts. ie (2.5 * v) +10
    is that possible and how do you do it.
    thanks'
    Nov 2006
    If you mean one of the pre-defined WO2 pids, like the PLX:
    ({EXT.AD1}*2)+10
    Then you will edit the entry in the sae.generic.txt located in:
    C:\Program Files\EFILive\V7.5\Configuration
    The best way to do this would be to add it to the calc_pid.txt so
    it won't be overwritten after a software update.
    LC-1 WBO2
    May 2009
    thanks for the reply.
    that's what I would like to install "({EXT.AD1}*2.5)+10"
    in C:\Program Files\EFILive\V7.5\Configuration, sae.generic.txt.
    now the next problem
    error reported
    required parameter ext.ad1 at position 10 not selected,
    there is always something else.
    thanks in advance
    how do you select this?
    Select the pid EXT.AD1 (on the PIDs tab double click on it).
    Beware: when you update to a newer build version of V7, the file sae_generic.txt will be overwritten (your edit will be lost).
    May 2009
    there we go, I wasn't looking in the drop down menu labeled "system", to select "Externals"
    thanks, I'm getting a reading now.
  1. How to Modify calc_pid for 14.12 Stoich using PLX WB?
    Last Post: April 25th, 2010, 06:03 AM
  2. Modify odometer?
    By Koerbs in forum General (Petrol, Gas, Ethanol)
    Last Post: August 15th, 2009, 03:14 AM
  3. How to modify calculated PIds
    By 2000ssnb in forum Tips and tricks
    Last Post: July 4th, 2008, 04:14 AM
  4. How to modify commanded A/F @ WOT?
    By LS1-450 in forum Gen III V8 Specific
    Last Post: June 10th, 2008, 04:35 PM
