getting error bad secret token when updating now
Are you manually downloading the V7.5.6.170 and V8.1.2.160 from the main www.efilive.com downloads pages? Dont use auto update, currently its been messing up installs.
Also make sure you right click and run as administrator.
I keep getting this message when I connect the V2 to my 02 Z06.
Uninstalled,rebooted,deleted the directory and searched the windows registry for 'EFILive' and deleted all the keys. restarted and reinstalled w/ a new download. still getting the error.
Any logs you need to help w/ this?
Did you update the firmware in the V2
If you downloaded 7.5 and 8 and updated the firmware to .14 and now you're having the problem, try running the V7.5 check for new update.
Ira
