Page 1 of 3 123 LastLast
Results 1 to 10 of 30
Thread: Tunring Pilot off completely ??
    Jul 2011
    Default Tunring Pilot off completely ??
    Well I have the pilot even off completely and something i have noticed is that when engine is cold, say at the start of your day, start up is rough with lots of white smoke, then given about 60 seconds or so it clears up and runs perfectly fine. When engine is warmed up to operating temp or close it starts fine.
    Seems like timing is in need of adjustment. This occurs with nothing else modified or whether tuning has had a few other modifications. Cant be too hard of an adjustment.
    Truck drives out great otherwise its just when cold cranking then it finally levels out. I was thinking of increasing timing but not sure how to go about it .
    Need some clues!! Thanks in advance!
    PS... Even before i had efi live , when cold i would notice a slight puff of white smoke. This just seems more exagerated version of that. I always thought of a stuck injector.
    Nov 2010
    Timing adjustment is needed at idle for a no-pilot cold start to happen. Without pilot your either looking at a 15* main event or if the 20* offset is a factor your looking at a -5* main event. Which would account for the white smoke..
    Try bumping main timing at idle up to 30* and see how it runs.
    ~Les
    Les Szmidt
    2007 5.9 Dodge Ram
    EFI Live Cummins BETA Tester
    Silver Bullet Tuning
    silverbullettuning@gmail.com
    www.youtube.com/ljszmidt
    Jul 2011
    Quote Originally Posted by 2007 5.9 View Post
    ~Les
    Are you saying change it in the base table and the 4 tables there after?
    Jul 2011
Name:	Main Cranking Timing.PNG
ID:	11374 HERE?? OR in the other tables i asked about?
    Nov 2010
    I'm pretty sure when I did mine I just changed the base timing table.... When I get home at my computer, I'll look through my notes and give you a definitive answer.
    ~Les
    Les Szmidt
    2007 5.9 Dodge Ram
    Jul 2011
    ~Les
    Patiently waiting!
    Nov 2010
    I just looked at my notes....looks like I set all tables (main,adjust 1,2,3,4) all to 25* with no pilot. Seems that it worked well cold, but driving with my large turbo was impossible.
    i now run a modified pilot, main and post table...
    ~Les
    Les Szmidt
    2007 5.9 Dodge Ram
    Jul 2011
    the complete table to 25* or??? sorry for my ignorance.
    Jul 2011
    ~Les
    Nov 2010
    Yes, the entire table to 25*
    ~Les
    Les Szmidt
    2007 5.9 Dodge Ram
  1. cant completely disable VATS in 01 holden SS?
    By Dopey in forum Gen III V8 Specific
    Last Post: September 29th, 2011, 06:58 PM
  2. How does one completely delete the knock sensors?
    By the Dragon in forum Gen III V8 Specific
    Last Post: March 27th, 2009, 11:38 PM
  3. And now for something completely different
    By Chevy366 in forum Lounge
    Last Post: September 16th, 2007, 04:02 AM
Tags for this Thread
