Results 21 to 30 of 44
Thread: CALC. VE Problems
  1. #21
    Jul 2008
    No wrong calc_pids.txt. You need to referencing this page: http://forum.efilive.com/showthread....VET-In-Reverse
    Use the calc_pids.txt on that page.
    No spreadsheet for smoothing the VE Table. You can use the smoothing techniques found on this page: http://forum.efilive.com/showthread....-Summary-Notes
    Good luck.
  2. #22
    Dec 2005
    Thank you Shawn. In the Calc you suggested above I will need to set up for my LC1 correct?
  3. #23
    Jul 2008
    Quote Originally Posted by 1bar View Post
    Yes. If Analog Wideband you will need to set up your calc_pids.txt file to include that.
  4. #24
    Yes, make sure your VET-in-reverse calc_pids.txt contains this:
    Code:
    *CLC-00-110
    factor             0.5           1.5       .4  "{GM.EQIVRATIO}*{CALC.AFR_LC11}/14.7"
  5. #25
    Dec 2005
    Hello Joe,
    Yes my new VET in REV calc has the above text in it.
    Two questions.
    1. In my scan tool I have a "WO2BEN factor" map that I plan to use to auto tune with. I made it the same as the SELBEN factor map in the Vet in REV page only using WO2BEN. Is this correct?
    2. I cant set up the filters the VET in REV page tells me to. For some reason I can't pick OR to join parameters.
    Thank you,
    Glenn
  6. #26
    1. Yes, correct, set the CLC for SELBEN to "{CALC.WO2BEN}" (edit only the stuff in between the quote marks).
    2. Can you post a screenshot...
  7. #27
    Dec 2005
    Hello Joe,
    1. Ok in the Calc_pids I changed all of the SELBEN in quote marks over to WO2BEN with quote marks.
    2.What is the easiest way to attach a screen shot. Its been over a year since I've done one.
    Thank you,
    Glenn
  8. #28
    Jul 2008
    Glenn, try this link for information on hosting an image: http://forum.efilive.com/showthread.php?3064-Hosting-an-Image
  9. #29
    Glenn, post the calc_pids.txt you are going to use.
  10. #30
    Dec 2005
    Ok attached is my scanning software and the filters that I am not able to set up?Click image for larger version.
    As well as my Calc_pids.txt.calc_pids.txtClick image for larger version.
    I think the Calc pids is correct. I cant set up the filters. Is it because I haven't done a log yet with the new Calc in REV set up?
    I think I have my map set up correct as well.
    What do you think?
    Thank you,
    Glenn
  1. Trying Calc.ve--need help
    By JWolfe75 in forum Gen III V8 Specific
    Last Post: October 10th, 2010, 06:50 AM
  2. Calc VE Setup
    By DPS in forum Tutorials
    Last Post: April 18th, 2010, 10:48 AM
  3. Calc.ve
    By whackem04 in forum Gen III V8 Specific
    Last Post: October 1st, 2009, 03:14 PM
  4. Problems with Speedo Calc. / PLEASE HELP
    By Boost in forum E37, E38 & E67 PFI ECM's
    Last Post: April 17th, 2008, 11:17 PM
  5. Calc.Torque
    By purrvert in forum General
    Last Post: May 10th, 2007, 03:32 AM
