Results 1 to 8 of 8
Thread: New memory type for new PCM's
    Default New memory type for new PCM's
    This is why we are going to have a heck of a hard time reading the code out of the newer cars...
    But I hear Ross has some ideas on how to work around that....
    http://www.national.com/rap/files/datasheet.pdf
    It's not problem, GM's new generation ECM's (E39 & E78) which of course we already support have the flash memory built in to the CPU, so I guess we are good for a few more years. The only issue we face is like what GM have done on the LML ECM where reading via the OBD-II port is non functional.
    swingtan
    Guest
    Bwahahaha, that's a classic! I love the cooling requirements and the block diagram, not to mention the "Number of pins remaining vs. Number of socket insertions" graph.
    Yeah that cracked me up too.... I used to write specs off datasheets like this, so reading this is hilarious!
    lol... each paragraph is roflmao material.
    that's ideal for military applications, keeps the operating data secret.
    Lifetime Member schwoch1's Avatar
    Jan 2009
    Wow..... Six foot fan to cool, oughta kinda be hard to install in a car with them cooling requirements!!!
    Mike
    Current toys are as follows:
    1961 Chevrolet Corvair Monza, 145 H6/powerglide. 85 HP of raw fury.... slow and stock and staying that way!
    1969 GMC 2500, 4-53T Detroit diesel/Fuller 10 speed on late model 1500 HD frame
    1970 GMC 9500, 6-71 Detroit/Fuller 13 speed, not sure why I bought it, but it sure is noisy!!!
    1975 Ford F100 shortbed. Currently undergoing Crown Vic subframe swap and EFI 4.6!!!
    1975 Chevrolet Vega, 5.3/200-4R may finish someday, maybe...
    Write Only Memory
    Robert Pease is a good engineer with a good sense of humour, I have been following his columns for years.
    Jun 2011
    For a second I thought that this was a real topic. I've seen that before about a year ago when designing some stuff... Unfortunately I've heard bus encryption is something the computer industry is either using or working on... doubt anyone would have a good reason to use it on real time hardware though.
  1. Is this a type-o?
    By SGFastMax in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: March 12th, 2011, 05:18 AM
  2. More Memory ?
    By L31Sleeper in forum FlashScan V2
    Last Post: November 23rd, 2010, 12:12 PM
  3. PCM Type and Protocol. Work in progress
    By CalEditor in forum Lounge
    Last Post: May 29th, 2008, 04:47 AM
  4. What type of card does V2 take?
    By redhardsupra in forum FlashScan V2
    Last Post: March 28th, 2007, 08:29 AM
  5. Airflow and PCM memory.........GMPX, Blacky, gojo, Delco...
    By bink in forum General (Petrol, Gas, Ethanol)
    Last Post: November 10th, 2005, 09:49 AM
