Results 1 to 10 of 20
Thread: HELP! PLEASE HELP!! Truck won't start!
    Senior Member Wasted Income's Avatar
    Dec 2005
    No, I did not need to pull any battery cables. I just bumped the key and it fired right up.
    The only aftermarket electronic device I have on there, is a PAC auxillary input adapter (2 RCA stereo inputs). I was able to log data just fine with EFI live, and my Diablo Predator never had a problem backing up or flashing the ECM with this installed, so I'm hesitant to blame it. However, if it continues to give me grief, I will remove it and give it a go.
    2005 Silverado Duramax LLY - EFI Live Tuned
    1969 Chevrolet C-10 Pickup - Turbocharged 5.3L/4L80E - EFI Live Tuned
    1975 Avenger Jet Boat - 6.0L/Berkley pump - EFI Live tune in progress
    That's fine, sounds like perhaps it is not going to be a vehicle side problem afterall. I just mentioned it because some aftermarket gear doesn't seem to conform to GM's communications standards.
    When you next try and if it fails again, EFILive saves some files that record the attempts to read etc. They are located in -
    My Documents\EFILive\V7\Bug reports
    There will be a file called 'upload.blx' or similar, if you could please mail that to ross@efilive.com I can have a look and see what is going on.
    Also, make sure you have the 'high speed' box ticked in the read PCM box that opens up (it is by default).
  1. help truck wont start!
    By chev in forum General (Diesel)
    Last Post: March 29th, 2010, 02:39 PM
  2. 'Race truck' wont start..
    By nonnieselman in forum Gen III V8 Specific
    Last Post: January 12th, 2010, 08:33 AM
  3. HELP 911 Cannot start truck
    By Airtime in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: September 26th, 2009, 12:08 PM
  4. MY TRUCK WON'T Start, HELP
    By ptownbacker5 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: October 6th, 2008, 09:43 PM
  5. TRUCK WON'T START AFTER DSP5 instal
    By vortecfcar in forum General (Diesel)
    Last Post: June 8th, 2007, 05:43 AM
