Results 11 to 20 of 53
Thread: E37 anti theft disable
    Yes, just hardware/software that you can't see, this makes it magic... and it being convoluted makes it black magic.
    Dec 2007
    I'm with Joecar. The EFILive team are wizards. If they werent, everyone would be doing it.
    Aug 2010
    Quote Originally Posted by MisterBill View Post
    lol there is no wizardry here...this is not magic just hardware and software.
    If it is just hardware and software then yourself and samgm2 should be able to figure it out with asking the rest of us for help - unless you don't understand the "hardware and software".
    The intent of the "wizardry" comment (which the rest of us understood) was to pay a little respect to the folks at EFILive that have the ability to combine computer science with art (or generating solutions by thinking outside of the box).
    You and samgm2 have "big plans" for your ethanol project - but as of yet, you can't even get the vehicle to start.
    When you have your "hat in hand" and are asking others for help, arrogance is never a good approach.
    Regards,
    Taz
    Jul 2011
    Quote Originally Posted by gmh308 View Post
    Anti theft is a distributed function. Its about the right key in the right ignition lock with the right BCM, right instrument cluster, right ECM, right anti theft module etc etc etc. Anti theft does control cranking, but it does not do it in any one module.
    And just what determines if a ECM, cluster...etc etc is "right"? This is where research seems to return conflicting information...nobody seems to know.
    The purpose of the VATS patch in ECM is to enable the ECM to run an engine in a conversion without all the other anti theft bollox that comes with a regular production car. Set VATS patch to applied, save, full flash. VATS patched. Why do you want to patch VATS out?
    Why we want to do it is irrelevant.
    The "full flash" button is not enabled, but I don't know if Sam as tried Version 8 yet as Erik mentioned earlier. Why would the "full flash" button be disabled in 7.5?
    Aside from the starter relay check are there any other steps required to enable the engine to start?
    In some calibrations GM tests for presence of the starter relay. If it is missing then no start. i.e. crank but no start. Normally disabling the starter relay check and or setting relay type to none will work. Or use a resistor to ground the starter relay pin on the ECM.
    So you're saying disabling the starter relay check does not always work.
    The resistor may need to be to 12V depending on the year...some pull it down, some pull it up.
    What security light?
    The one in the instrument cluster of course
    Jul 2011
    Quote Originally Posted by Taz View Post
    Regards,
    Taz
    Oh there is definitely a sufficient level of not understanding a lot of this! No question about that. My comment was in no way shape or form intended to convey arrogance, if anything I am an overly modest person. If that is how it came off then I do apologize. I just hate when engineering is referred to as magic...it is not.
    Dec 2007
    For all the modules to be right, the need to have the same VIN. They need to be VATS learned. This enables all modules to determine that they have agreed on the same security code. They go through a nominal process of exchanging secret key etc so that they cant be hacked. If you have a 2010 ECM, and you have not run VATS learn, then that explains a no start and maybe the security light. The 2010 ECM may not even be compatible with the earlier VATS sequence. GM makes changes often every year. All this is pretty well documented by GM in their publications.
    Full flash button normally arcs up when tune tool is started with the V2 plugged in with the tune tool authenitcated to the V2. Pretty straightforward.
    Sometimes the starter check is used by the calibration, sometimes not. The Efilive option always seems to work. The check type if used is defined by whether the relay connects to ground or to 12V. If its to ground then the ECM pin may want to see current to ground.
    Dec 2007
    Regards,
    Taz
    Thats the 2nd funniest quip I read tonight .
    The reference to magic is a euphemism for the convoluted or unknown portion of a system and that the system functions in spite of being convoluted/unknown... it no way implies magic in the traditional meaning of the word.
    When an engineer refers to magic he/she means any of the following:
    - conditions are just right and everything connects/clicks/functions and generally comes/falls together very nicely (when you design a board to carry high speed signals you will know magic and antennas)(skiiers also use upon being able to perfectly carve snow),
    - a subsystem which is so simple and functions so well/flawlessly is magic (e.g. 555 timer chip),
    - a subsystem whose detail is hidden/obscured/protected from view so it is magic,
    - a subsystem whose detail is so convoluted/difficult to understand so it is magic that it works without bugs.
    There is a famous quote: "Engineering is a mixture of art, science and [black] magic"... I think Robert Pease quoted/requoted this.
  9. #19
    Jul 2011
    I design high speed printed circuit boards and microwave antennas for a living...do not tell me it is magic, it is NO such thing. Granted RF is a different animal that doesn't tend to play by the normal rules...but there is no magic involved. Building anything that "magically" works is NOT engineering.
    My simple joke of a comment was in NO WAY SHAPE OR FORM intended to undermine the efforts of the EFILive engineering team. If it was taken that way, well it was not in the slightest intended that way. I KNOW the effort it takes to develop anything intended for a system developed by someone else, been there done that. Granted that was with older TBI systems...but believe you me I completely appreciate the amount of effort!
    With that said yeah I can see where the term may be used in a completely different context...guess I just don't agree with the humor in it.
    Anyway I'm done with the useless silly stuff. Moving on...
    All I care about is why this <explicative> engine won't start with the 2010 ECM/TCM combo. Sam said he was able to do a VATS-disabled full flash with the V8 software but that made no difference (and regardless of how straightfoward anything should be...the full-flash button IS NOT enabled in 7.5, for whatever reason I don't know). Speaking of the VATS disable...there are something like three options (forgive me I don't have the software in front of me at the moment) and we are not finding anything that explains very well just which one of these options we are supposed to be using. I think it was different "Types" maybe? (Type 1 VATS, Type 2 VATS..etc) How do we know which one is appropriate?
    It could also very well be that VATS has been disabled all along and there is still a problem with the starter relay diagnostics (or whatever that is called). In studying the wiring diagrams I discovered that the starter relay signal is not only on different ECM pins between 2007 and 2010, but is of different polarity (2007 ECM pulls the relay coil down, 2010 ECM pulls it high). In addition to that, in 2007 the P/N safety switch is in series with the starter relay, where as the 2010 P/N switch is not. I have rewired the P/N switch signal to the correct pin on the 2010 (and inverted with a relay to match what the 2010 ECM is expecting for the P/N signal), but I think wiring the starter relay to the 2010 diagrams was a mistake, since the BCM is going to send a "start command" to a 2007 ECM, not a 2010 ECM.
    Seems the next step is to provide the ECM with an appropriate starter relay signal. As long as VATS is disabled there really shouldn't be anything else preventing this thing from starting, right?
  10. #20
    I think my point was completely lost... but anyway, carry on with starter relay diagnostics.
  1. VE SS commodore Anti theft
    By limited cv8r in forum General
    Last Post: May 23rd, 2010, 03:34 PM
  2. Anti-Theft???'s
    By GAMEOVER in forum Gen III V8 Specific
    Last Post: November 9th, 2009, 07:17 PM
  3. torque,anti abuse?
    By 2004gmc in forum Lounge
    Last Post: May 28th, 2009, 02:52 PM
  4. Theft disable
    By VHR in forum General (Diesel)
    Last Post: July 7th, 2008, 11:35 AM
  5. Why do you have to change Theft settings?
    By Tordne in forum RoadRunner Real-Time PCM Emulator
    Last Post: June 21st, 2007, 01:55 PM
