Thread: What else could pull timing?
    Oct 2003
    Default What else could pull timing?
    I’m noticed some slightly strange timing behavior under moderate load that I have not been able to figure out.
    My high and low tables are set the same. The car is a boosted c5 Corvette running the custom OS in SD and the drop in timing only seems to happen around 4000 rpms under decent load. I’ve logged all the timing PIDs and nothing seems to show where the timing is going.
    The EST_BASE_DMA PID will show something like 19.2, but the EST_RUN_DMA PID will show something like 16. The SPARKADV PID is a pretty close match to the EST_RUN_DMA.
    I’ve logged almost all the other spark PIDs and nothing shows any timing being pulled.
    KR
    EST - Burst Knock Retard
    EST- Coolant Temp Spark
    EST - Equivalence Ratio Spark
    EST- Induction Air Temp Spark
    EST – Total Torque Control Spark
    EST – Traction Control Spark
    Is it possible for KR to happen, but not show up in the KR PID. I’m able to see KR readings, but not in this scenario.
    This is nothing major, but wanted to see if anyone had any other ideas.
    Oct 2003
    More info please.
    What are your referenced table spark values..High, low octane, base in and out of gear etc?
    Did you log "Spark Smoothing"...is it the same reduction in each gear?
    Oct 2003
    Quote Originally Posted by bink
    More info please.
    The base spark pid and the high/low tables match up. It is just that the run spark is a few degrees less.
    I did some more logging today(including the smoothing PID) and it did not seem to happen again.
    I'll have to keep an eye on it. I did disconnect the batt before the logging today, so I wonder if some type of learned data got reset.
    I suspect it will be torque reduction, these usually seem to be the culprit when going S.D.
    Oct 2003
    That would show up in the EST – Total Torque Control Spark PID, right?
    Anway, I'm pretty sure this was something else. Is there any type of knock learn....? I seem to remember something like that in the past.
    Jul 2005
    I had a similar issue but it was KR taking 7 deg away above 3600rpm. It was like a switch.The values in the old knock table got changed somehow during one of the reflashes.
    Took me a while to find the cause and caused much swearing and hair pulling.
    \"You Can Never Have Enough Horsepower\"
  1. Displacement not on pull down
    By dennisscars in forum IL6,IL5,IL4 Atlas Engines - P12 PCM
    Last Post: May 24th, 2009, 01:15 PM
  2. I'll try this in here, anyone get too much timing pull with COS5?
    By Loudmouth LS1 in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: March 31st, 2009, 08:25 AM
  3. Help, why can't I pull timing through my AIT?
    By 860 in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: June 6th, 2008, 11:32 AM
  4. Can't pull LS7 SMS and O2 data
    By leres in forum E37, E38 & E67 PFI ECM's
    Last Post: July 27th, 2007, 10:41 PM
  5. Pull timing with bidirectional controls to test for KR?
    By Xtnct00WS6 in forum General (Petrol, Gas, Ethanol)
    Last Post: August 27th, 2006, 04:11 PM
