Runway lighting works fine for me on 98-2006 PCM's but when try to use it on anything with an E38 or E67 ECm it doesn't. Example: On hi-octane spark table the RPM horizontal runway follows rpm's ok but the vertical air flow runway stays on the last coluum. Is there a trick to these that I'm unaware of?
