Results 1 to 3 of 3
Thread: 2002 Saturn L100
    Sep 2003
    Default 2002 Saturn L100
    My neighbor has some problems with the PCM talking to his BCM after the dealer did something. I was looking at the supported list and how can I tell the difference from 2000 - 2002 2.2L and the 2002 - 2004 2.2L PCMs?
    Can I just read his PCM and hope everybody (PCM & BCM) plays nice after the read?
    TIA.
    Oct 2004
    They probably look different. You could also perform the Auto Detect using the V8 software to see if it is able to determine the ECM type. If it doesn't detect it then it is not going to be a supported ECM (more than likely).
    Andrew
    EFILive Crew
    Sep 2003
    Thanks.
  1. 99 Saturn crack log
    By sabercatpuck in forum IL4, 97-01 PCM and 02+ P11 PCM
    Last Post: February 19th, 2012, 11:57 AM
  2. 2004 Saturn Ion Scanning??????
    By BlkMax in forum IL4, 97-01 PCM and 02+ P11 PCM
    Last Post: November 18th, 2011, 10:55 AM
  3. Saturn Vue 3.6 E67 PIDs
    By Boost in forum E37, E38 & E67 PFI ECM's
    Last Post: June 15th, 2011, 11:48 PM
  4. Saturn Ion Redline Unrecognized PCM
    By Dynotuner in forum IL6,IL5,IL4 Atlas Engines - P12 PCM
    Last Post: August 9th, 2010, 10:18 AM
  5. 2003 h2 and 04 saturn ion
    By blackdeath in forum General (Petrol, Gas, Ethanol)
    Last Post: February 17th, 2009, 05:09 PM
