Thread: E38 6.0 Streetrod/Stanalone Swap - Very little ignition TIming
    Aug 2011
    Default E38 6.0 Streetrod/Stanalone Swap - Very little ignition TIming
    Hoping someone can help me out-
    I've installed a 2008 6.0 and transmission into a street rod. I have a timing problem. The engine runs proper timing at idle and part throttle cruise, but as you tip into the throttle the timing decreases significantly all the way down to the 0-5 degree range. I have shut off all of the normal things you would in a street rod type application. I am using the T42 TCM. I am using a E38 ECM with a 2007 4.8 liter calibration to get around the cylinder de-activation system.
    There are no codes in the ECM or TCM, but I'm thinking there is something that it doesn't like.
    Any help or educated thoughts would be appreciated!
    Jim
    A log and a tune file will help out.
    Al
    sorry duplicate
    Dec 2007
    Is "tip in" torque mgt active?
    OK, we definitely need a tune if you're trying to use a different OS with a different size engine. Did you set the cylinder volume correctly?
    Are you running a MAF?
    What do you mean "get around the cylinder deactivation", just using a tune without it doesnt turn it off...you should really disable everything from the original tune (or a tune for your engine from a different platform).
    swingtan
    Guest
    There are a number of things that may be causing this.
    • Torque Reduction from the TCM.
    • Torque Reduction in the ECM.
    • If the original tune file was for a manual, you may be triggering CFCO timing.
    • Any of the many spark correction maps for ECT, IAT, ETC.
    As Erik says, post a log and the tune.
    Simon.
  1. e38 4l80 swap 07 silverado cant get speedo to work???
    By b18cls1 in forum E37, E38 & E67 PFI ECM's
    Last Post: July 6th, 2010, 02:45 AM
  2. Ignition timing issue,bank to bank
    By AllOutPerformance in forum Gen III V8 Specific
    Last Post: December 5th, 2009, 12:38 PM
  3. E38 AC management in an engine swap...
    By harascho in forum E37, E38 & E67 PFI ECM's
    Last Post: June 7th, 2009, 10:48 PM
  4. Transmission swap in E38/E67 vehicle.
    By XLR8NSS in forum Gen IV V8 Specific
    Last Post: February 2nd, 2009, 10:04 AM
  5. Ignition Timing
    By VetPet in forum General (Petrol, Gas, Ethanol)
    Last Post: May 30th, 2006, 03:47 AM
