Results 1 to 10 of 12
Thread: new stall tuning
    Jun 2010
    Default new stall tuning
    Just put in my new trans and circle d 3200 stall.
    No codes were thrown but im getting a lower idle and shifting is acting funny.
    What needs to be changed to make it drive better?
    I can log it and post if needed.
    thanks
    Post some logs.
    Jun 2010
    got some logs today.
    some just light cruising throttle and some higher throttle runs
    I'm out of town this week so I can't view thw logs... basically up the min and max TCC PWM, and possibly lower the WOT shift point (if it doesn't do the WOT shift).
    Aug 2011
    can't see logs....
    May 2010
    I can see the logs fine.
    1997 S10, 06 trailblazer SS LS2 swap, 4L70E trans, 76mm turbo. Factory ZQ8 suspension. 3.08, G80 w/a zexel. With a 0411 swap.
    Jun 2010
    What should i set the tcc pwm to?
    try these settings
Name:	ScreenHunter_03 Aug. 07 08.33.jpg
ID:	11596   Click image for larger version.
Name:	ScreenHunter_04 Aug. 07 08.33.jpg
    330 rwkw EFILIVE OS 01290005 SD Cam / Head Tuned 6 speed VY SS Commodore
    10/71 Blown 572 Big Block Chev HQ 2 Door Monaro
    GM Performance Centre
    Busselton WA
    AUSTRALIA
    Phone: 0447 003050
    May 2008
    Looking at these were a huge help for me
    http://forum.efilive.com/showthread....ight=vigilante
    2003 Chevy S10 4.3L LU3 LS1B Auto
    48 LB injectors
    Race Proven Motors 2114 intake
    T70 turbo.
    Jun 2010
    ill try thoses settings then see how it reacts, should i also zero out the shift times?
  1. Tuning for circle d 3200 stall
    By 05gmcsierra in forum Gen III V8 Specific
    Last Post: July 22nd, 2010, 11:32 AM
  2. Do I need to tune my old stall?
    By BowlingSS in forum Gen III V8 Specific
    Last Post: April 17th, 2009, 12:44 PM
  3. what stall to use
    By Adam Calley in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: September 14th, 2008, 08:54 AM
  4. Tuning for a big stall. yank 4400
    By smokin2002 in forum Tutorials
    Last Post: June 8th, 2006, 12:49 PM
  5. Tuning for a 3000 stall torque converter
    By dirt_track_racer_81 in forum General (Petrol, Gas, Ethanol)
    Last Post: June 5th, 2006, 03:03 PM
