Page 1 of 3 123 LastLast
Results 1 to 10 of 28
Thread: Digital $30 trans PSI sending unit, works great!
    Lifetime Member Mr. P.'s Avatar
    May 2007
    Default Digital $30 trans PSI sending unit, works great!
    This is not a how-to but more of an FYI -
    I found a cheap accurate pressure sending unit on eBay for $30 shipped (pigtail included!), I verified its output with several known sources (air compressor & gauge, and mechanical trans pressure gauge) and it works a treat. The seller is "renbusan" and the eBay store is named "Industrial-stuffs". The sending unit I used is labeled "500-psi", is accurate to +-2%, runs on a +5-volt source, and has a third wire which is the sensor voltage output which can easily be monitored as a Flashscan analog input, the formula for the custom PID = "iff({EXT.AD3} > 0.4, ({EXT.AD3} - 0.4) / 0.0077, 0)".
    Mr. P.
    PS - the same seller has a 100-psi sending unit that would also work well for monitoring fuel pressure, for $30-shipped - this is by far the cheapest option I have seen for a fuel pressure sending unit, although I don't know what the PID for it would be (you would have to determine that with testing). The next cheapest fuel pressure sending unit that I know of is the $65 one sold by Aeroforce.
    2003 Silverado SS, with Novi-1500 "CAI mod"
    EFILive V 7.5 COS-3 (OLSD, for now!)
    Senior Member Chuck L.'s Avatar
    Here's the link..
    http://cgi.ebay.com/ebaymotors/Press...Q5fAccessories
    Sure beats the $135 from Summit!
    Chuck L.
    CODY Motorsports
    Fuel Injector Service
    Madison, GA.
    706-342-3152
    770-265-5144 [C]
    May 2007
    For all we know they might even use the same ASIC inside!
    Hmmm thats really tempting, and Id probably get the 500psi for trans and a 100psi for fuel. Not running boost yet, but for $30 its cheap insurance that your pump is putting out the correct pressure. And be able to see what you're actually getting vs commanded trans line pressure...
    Jun 2007
    anyone try the 100psi? i think I'm going to buy one. says linear output. would this work for turbo backpressure also?
    9.8@150 . LQ4 Turbonetics Billet 7575@18psi, 6 speed, non-intercooled with meth. Speed Density, open loop, no PE.
    May 2008
    Probably not, the exhaust side is pretty hot.
    2003 Chevy S10 4.3L LU3 LS1B Auto
    48 LB injectors
    Race Proven Motors 2114 intake
    T70 turbo.
    Aug 2011
    much less expensive than summit...
    You could use the sensor with a length of copper tube as a heat sink. I did that w/ a common gauge and had no problems..3' of copper tube.
    Chuck L.
    CODY Motorsports
    Madison, GA.
    706-342-3152
    770-265-5144 [C]
    Aug 2011
    Quote Originally Posted by Chuck L. View Post
    Here's the link..
    why cant i find that kind of price these days. sigh.
    Jun 2007
    i ordered that ebay one yesterday
  1. Digital Dash
    Last Post: January 5th, 2010, 06:44 PM
  2. Oil Pressure Sending Unit - Recommendations?
    By Johnnydangerously in forum General (Petrol, Gas, Ethanol)
    Last Post: June 12th, 2009, 03:37 AM
  3. Replies: 2
    Last Post: April 18th, 2008, 09:00 AM
  4. I6 Scanning Works Great
    By LSRacing in forum Petrol / Gas
    Last Post: February 22nd, 2006, 04:16 PM
