Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: frequent failuer of cooling system and AC after flashing
    Apr 2008
    Default frequent failuer of cooling system and AC after flashing
    Hi,
    In many occasion when I tune E38 ecus, the engine coolant gauge fails and the AC goes off. In some events, code P0128 gets on. If I remove the battery or clear the code the car goes back to normal but the issue appears again later after sometime.
    If I return the stock file back, the problem goes away for ever. Please advice what could be the reason.
    Thanks in advance,
    Regards,
    Odd Boy
    What year / model vehicle?
    Apr 2008
    It happened with many cars, the following list is what I recall:
    Yukon--------12614088---2008
    Tahoe--------12639835---2011
    G8 (Holden)---12612381---2007
    Mainly happened with the Sierra, Tahoe, Yukon, and G8 Holden version for the middle east. Any model 2007+ but not all of them--
    Regards,
    Odd Boy
    Ok, all E38 vehicles, anyone else seen this problem?
    Apr 2008
    By the way in few cases, this issue goes off when I set P0128 to no mil and not reported in case a thermostat is installed and the fan batch is applied. However, MOST of the time it doesn't clear out and stays there until I return back the stock file especially with the stock car "without thermostat installed".
    for Example,
    Yukon--------12614088---2008 is a stock car with out thermostat installed. He came to me yesterday with the issue and it cleared out only with the stock file.
    G8 (Holden)---12612381---2007 , I encountered two cars with the same issue, both had thermostat installed. One of them got resolved with switching off P0128 and the other one needed to go back to stock.
    Another example, Tahoe 2007 but I don't have the file in hand now. with out thermostat installed and needed to go back stock.
    Please lemme know if the above explanation is unclear.
    Thanks,
    Regards,
    Odd Boy
    Dec 2007
    I have noticed on a 2010 camaro after a flash the ac isn't working but to be honest the cars a/c didn't work very well even before i retuned it. I need to check that out after the idle issue is fixed ill let you know if i see any a/c issues.
    David McLain
    www.etdrag.com
    Apr 2008
    I had the same issue again with two cars today, any help please...
    Regards,
    Odd Boy
    Odd Boy, the ones you have trouble with, are these only with the thermostat removed and the Fan rescale patch applied?
    Apr 2008
    yes sir, except one Yukon--------12614088---2008
    I don't want to push you but I am losing these customer, they think I made problems to their cars!!!!
    Regards,
    Odd Boy
    Odd Boy, I think you need to do a process of elimination. If you can put the stock file back in and everything starts working again then it's got to be something being modified in the tune that is causing it.
    Like the Yukon, have a look at the history of changes and think about something that has been disabled that may have upset the A/C system. I must admit I can't think of what could be causing it. I know David posted in this thread about a 2010 Camaro that has been a problem car for him that is having A/C issues, but apart from you two I have not heard of these sort of problems with E38's, unless files from different vehicles are flashed in.
  1. Replies: 6
    Last Post: January 4th, 2012, 11:46 AM
  2. E38 pwm cooling fan control
    By vette5797 in forum Conversions / Aftermarket Parts
    Last Post: December 24th, 2009, 05:07 AM
  3. E38 Cooling fans question
    By Chalky in forum E37, E38 & E67 PFI ECM's
    Last Post: September 1st, 2009, 01:11 PM
  4. Well guys I'm baaaaaaaaaaaaaack!!! Cooling fan OS problems.
    By ssvolvo in forum Gen IV V8 Specific
    Last Post: May 1st, 2008, 10:21 PM
  5. Burping the LS1 cooling system (questions)
    By joecar in forum Lounge
    Last Post: November 21st, 2006, 07:52 AM
