a couple questions for you more experienced guys. first, im trying to look at my flashscan firmware programmer for the v7.5 and it keeps tellin me that im in dead poll or when its connected to the truck, it says "cannot connect to flashscan v2. a device attached to the system is not functioning. win32 error: 31? firmware is ok for the v8 and i can log and tune with the v7.5 software? maybe im just missing something? i checked all this after i had downloaded the july 31st pre release and didnt have the new tables (E2536 and E2567) when i opened up the tune tool. my other 2 questions are, my fuel pressure reg.base duty cycle table (D0790) is set at 0% at 0 rpm and goes up to 36%. should that be adjusted throughout the rpm range staying at 0% at 0 rpm and increasing say up to 90-100% at 3500 rpm? also, my Fuel Pressure Reg, Max Duty Cycle % (D0791) is set at 71% from 600-3500 rpm. can i change that to 100% for the whole rpm range? sorry for the long post. hope someone can shed some light on this. thanks
denny
