Page 1 of 8 123 ... LastLast
Results 1 to 10 of 73
Thread: Release Candidate 2, Aug 19, 2011
    Default Release Candidate 2, Aug 19, 2011
    Release Candidate 2 of the EFILive V7.5 and V8 software is available for download.
    This software update is a release candidate version. You may use this version in a production environment.
    Auto Update:
    Due to as yet unresolved problems with the automatic updates, the Auto-Update feature has been disabled,
    you must manually download and install the release candidate software from the links below.
    Manual download/install available here:
    Important information
    New ECM Support: E83 (Service #12636386)
    We have added the ability to read and flash this ECM, however, no calibration files have been provided in this beta release, we are just looking for stock tunes to be Emailed in.
    The E83 is currently used on the following US vehicles: (there maybe other European / Asian Chevrolet branded markets also using this ECM)
    • 2011-2012 Chev Cruze 1.8L (LUW)
    • 2009-2011 Chev Aveo 1.6L (LXV)
    • 2009-2010 Pontiac G3 1.6L (LXV)
    • We also expect the new 2012 Chevrolet Sonic to use the E83.
    Bosch gas ECM read/flash:
    This beta also gives users the ability to read and flash the Bosch E55, E69 & E77 ECM's. It is important to understand that EFILive is not actively working on providing a full tuning solution for these ECM's. We have however had a number of customers request that we allow the ECM's to be read and flashed using V8 (V2 or Autocal) as they are using tuning packages from Europe that allow them to save files in open .bin formats. All they wanted was a way to read/flash the ECM's.
    There is no stream option for these and it will cost you $99 per vehicle. There has not been extensive on vehicle testing for these ECM's, hence, it's beta.
    Script Files
    Script files have been updated. The latest script files must be copied to FlashScan/AutoCal devices to maintain compatibility with the latest V2.07.21 firmware.
    Known Issues:
    Issue #1
    Attempting to read a CMB/CMC controller using standalone reading (BBR) when no vehicle is connected to FlashScan/AutoCal may cause FlashScan/AutoCal to hang. In that case you should power cycle FlashScan/AutoCal to regain control.
    Reporting Issues:
    If you discover any problems/faults, please make a note of them in this thread.
    For urgent or complicated issues, please create a support ticket here: http://support.efilive.com/
    What's new in this release candidate (since the July 03, 2011 public release):
    Grey text indicates changes made in the July 18 update.
    Black text indicates changes made in the July 27 update.
    Red text indicates changes made in the July 29 update.
    Green text indicates changes made in the July 31 update.
    Blue text indicates changes made in the Aug 05 release candidate 1.
    Orange text indicates changes made in the Aug 19 release candidate 2.
    V7.5.7 Build 178 (Aug 19, 2011)
    • Added BEN factors when using dyno lambda serial wide band PIDs:
      - CALC.BEN_DYNO Base Efficiency Numerator 1 - Dyno.
      - CALC.BEN_DYNO_B Base Efficiency Numerator 1 - Dyno LS2 style.
      - CALC.BEN_DYNO_E38 Base Efficiency Numerator 1 - Dyno E38 style.
      - CALC.BEN_DYNO_E67 Base Efficiency Numerator 1 - Dyno E67 style.
    • Fixed definition of PID GM.CASERL.
    • Fixed phantom DTC P2911 showing up in V7.5 Scan Tool.
    • Fixed address error for E38, table B1848 in OS 12633056 & 22633056.
    • Fixed address errors for table B1848 in E37 12628330, 12617248 and E67 12628999, 12635947.
    • Added two more limiting tables, E2536 & E2567 for Cummins.
    • The blue registration card "License Type" descriptions now correctly match the V7.5 licensing options in the "Register EFILive" Window.
    • Lowered H0101 hard-limit by 1% to prevent extremely high values from causing the PCM to fail.
    • Added three new states for the GM.TCCMODE PID: "Slew Releasing", "Slew Applying" and "No Change".
    • Removed FRPADES and FRPACOM from the V8 E35A (LBZ) and E35B (LMM) definitions.
    • Fixed V7.5 EFILive Firmware Programmer to correctly recognize the difference between V2.04.xx and V2.05.xx boot block versions.
    • Fixed out of range speedo calibrations not being detected reliably.
    • Fixed problem that caused calibrations (tagged in red) such as the VATs patch for E37 to not be visible for some users. I.e. those who are using FlashScan devices purchased new in the past few months.
    • Fixed LS1 speedo calibration H0104 showing as out of range when it was not.
    • Fixed menu option Edit->Copy for export to V8 so that it copies DMA PIDs correctly.
    • Added ftlb units to GM.TRQENG_C, Added psi units to GM.TFFFP
    • Fixed floating point error when displaying 3D surface maps "end-on", i.e. at rotations and elevations of multiples of 90 degrees.
    • Fixed Allison 6 speed H0102 speedo defintion for cal levels: 8P6 and 8P7.
    • Added thresholds for P2101 for E37, E38 and E67
    • Added Low Oil Pressure warning controls for E37, E38 and E67
    • Added new E38 OS's 12647991 (2012 Vette) & 12649046 (2012 Camaro).
    • Added support for 4 Cylinder OS: 9353692, 9351290, 9353418, 9355300 and 9364356.
    • Added support for new Cummins 5.9 OS: 11352408
    • Fixed buffer overflow in *.blx trace routines. The buffer overflow caused multiple, random and most times seemingly unrelated failures during subsequent read and/or flash attempts.
    • Fixed P12 2MB cal-flash failure.
    • Added support for new E67 OS 12635457 (2012 ZR1 Corvette and 2012 CTS-V).
    • CMB updates add D0511, Injection Pulse Limiter Control.
    V8.2.1 Build 166 (Aug 04, 2011)
    • Fixed user supplied unlock key being ignored.
    • Update selected PID lists when changing controller type in BBX setup instead of just deleting all selected PIDs.
    • Allow copy/paste of PID lists from V7 to V8.
    • Fixed LBZ/LMM V8 full-flash.
    • Fixed $0322 error when flashing some controllers.
    • Device settings are now automatically read from the connected/active device when opening Device Settings page in V8 EFILive Scan and Tune.
    • CAN full-flashing in V8 has been optimized for many controllers.
      Example speed increases: E39 full flash was 3:44 now 2:47, E38 full-flash is 20 seconds faster, T42 full-flash is now under 1 minute.
    • Forced HAPI window to be displayed when a firmware update is available - instead of the system tray balloon which was not obvious enough.
    • Fixed PID descriptions that were not displaying correctly for some EXT.DYNxxx PIDs
    • Fixed data corruption during fall-flash of E35A,E35B and CMB controllers.
    • Fixed flash failures for multiple VPW based controllers.
    • Relabeled buttons and check boxes to make them more meaningful in the Read, Cal-Flash and Full-Flash tab pages of the Tune window.
    • Added controller specific warnings prior to reading and flashing where necessary.
    • The Edit->Property menu option (and the [Config] button in the Tune window) has been activated. Currently only the Tuning Tool->Warnings item is available.
      • The Warnings property item can be used to turn various warnings on/off.
      • When you use the Edit->Properties menu option is automatically goes to the [General] item in the tree view.
      • When you use the Tune [Config] button it automatically goes to the [Tune Tool] item in the tree view.
    • There are two new right-click options in the blue sections of the BBx window. They are:
      • Check All Used Items: add a checkmark to all items that do not have "Unused" as their caption and remove checkmark from all items that do have "Unused" as their caption.
      • Invert Check for All Used Items: inverts the checkbox for all items that do not have "Unused" as their caption.
    • There is a new "Invert Selection" right click option on the green section of the BBx window.
    • Fixed controller serial number displayed in the [F3: Calibration] tab page for most CAN based controllers.
    • Fixed controller serial number displayed in the [F4: Properties] tab page for E54 (LB7) and E60 (LLY) controllers.
    • Enabled reading for 6.7L Cummins ECM & TCM.
    FlashScan/AutoCal Bootblock V2.07.03 (July 25, 2011)
    • Security Update.
    FlashScan/AutoCal Firmware V2.07.21 (Aug 15, 2011)
    • Fixed enumerated PIDs not displaying correctly on V2 BBL.
    • Fixed BBL not starting sometimes when LBZ/A40 controllers are being logged simultaneously.
    • Fixed AutoCal simple-menu read-options which incorrectly displayed existing file names for the last 3 read options.
    • Fixed CMB standalone flashing.
    • Fixed BBL problem where some PID's values were not being displayed correctly at the start of the log - until their value changed.
    • Fixed AutoCal BBL problem which caused the firmware to crash/reset when starting a log or selecting PIDs.
    • Fixed AutoCal failing to start BBL.
    • No significant changes.
    To update software/firmware, follow this procedure:
    Download and install V7/V8...
    then using V8 EFLive Explorer do this:
    - goto thew Firmware tab,
    - update the bootblock to 2.07.03,
    - update the firmware to 2.07.21,
    - exit from EE.
    then using V8 Scan & Tune do this:
    - goto the BBx tab,
    - click Read,
    - click Save (and if asked specify filename Options.txt),
    - click the down arrow on the Program button and select Format Config File System,
    - click the down arrow on the Program button and select Program All Required Data (Slower),
    - exit from the tab and exit from S&T.
    Also, using V8 Scan & Tune, do the same on the Devices tab (filename is Settings.dat).
    Thats a good, quick how-to update everything Joe. Maybe have Paul include it in his original post and in future ones?
    Downloading them now!
    Dec 2007
    Joecar great description on how to go about it
    I have never used the program all req data slower i tryied it and now i am getting an error $0194 any thing else i should try
    David McLain
    www.etdrag.com
    Dec 2007
    3rd time is a charm it work with no error the last time i tried ok lets see how the car likes it.
    David McLain
    www.etdrag.com
    Oct 2004
    I'm crossing my fingers David.
    Andrew
    EFILive Crew
    Quote Originally Posted by etmotorsports View Post
    That usually indicates the Config file system is full. That means there are most likely older (unused) files still left on the Config file system.
    The best thing to do if you get $0194 is to format the Config file system and the redo the [Program All].
    Or it could mean that you are just trying to configure and program support for too many controllers into FlashScan.
    Dec 2007
    Default Cannot program from 7.5
    Cannot program from 7.5 and if i save the tune in 7.5 as ctd i can't see it when i open up 8.2 :(
    14:56:44.356: Scanning for EFILive FlashScan V2 HAPI
    14:56:44.371: Autodetect interface ...
    14:56:44.605: Interface firmware version: 2.7.21
    14:56:44.605: Connection to [FSV2] interface is OK
    14:56:44.808: USB driver version: 2.8.20
    14:56:44.808: USB library version: 3.2.4
    14:56:44.824: Interface firmware model: FSV2
    14:56:44.839: Interface firmware model: FSV2
    14:56:44.839: Interface firmware version: 2.7.21
    14:56:44.855: Interface firmware date: Aug 15, 2011
    14:56:44.871: FlashScan serial number: 003648878494
    14:56:44.886: FlashScan license number: 003648878494
    14:56:44.902: Disconnecting ...
    14:56:45.432: CAN-VPW Bridge Deactivated
    14:56:45.448: Disconnected
    this is what it does is 7.5
    David McLain
    www.etdrag.com
    Updated instructions for installing updated software/firmware:
    Download and install V7/V8 (i.e. install by doubling clicking on the .exe files);
    - exit from EE.
    - goto the BBx tab,
    - click Read,
    David, does it give an error message in V8.2 when you try to open it...? Do you have a screenshot...?
  1. Release Candidate 1, Aug 04, 2011
    Last Post: September 11th, 2011, 03:36 AM
  2. March 05, 2011 release candidate 2
    Last Post: March 20th, 2011, 02:36 PM
  3. February 26th 2011 release candidate 1
    Last Post: March 4th, 2011, 09:55 AM
  4. January 31st 2011 pre-release (Updated Feb 03, 2011)
    Last Post: February 24th, 2011, 06:14 PM
