Results 11 to 20 of 38
Thread: Cant BBX read Tune, I get error $050B
    May 2008
    I found the reason why it's not working. If I download from your site it has the correct files but when I run the update program they get written over with an older version....So, your update is screwing it up!
    230" Dragster - 2000 LS1, 02020003 Speed Density, PRC 2.5 Heads,
    MS3 Cam 237/242 .603/.609, Vic Jr. intake, Holley 1000CFM TB,
    PowerGlide, 5000 stall converter. 8.70@154 MPH
    My Projects Homepage: http://www.horsepowerracing.com
    Lifetime Member 06redram's Avatar
    Jan 2011
    Quote Originally Posted by LS1_Dragster View Post
    I said you need to uninstall it
    Uninstall tune and scan tool reboot than reinstall both and than update from start, all programs look for EFI click you will see tune click update. Do the same with scan. When done update firmware
    May 2008
    I appreciate your help, and as I indicated earlier I did indeed uninstall it. I've been IT for 30 years!
    Also, like I said, it's their update that writes the wrong version files over the correct files.
    Jan 2011
    Got to u I am happy u got straighten out
    Aug 2011
    Hey Dragster, Did you fix the prob? I'm still have this prob.
    Quote Originally Posted by electricblue View Post
    Did you install builds 180/170 manually (double click on the V7/V8 .exe files)...?
    Aug 2011
    yep
    Did you follow these steps:
    Updated instructions for installing updated software/firmware:
    Download and install V7 build 180 and V8 build 170 (i.e. install by doubling clicking on the .exe files);
    then using V8 EFLive Explorer do this:
    - goto thew Firmware tab,
    - update the bootblock to 2.07.03,
    - update the firmware to 2.07.22,
    - exit from EE.
    then using V8 Scan & Tune do this:
    - goto the BBx tab,
    - click Read,
    - click Save (and if asked specify filename Options.txt),
    - click the down arrow on the Program button and select Format Config File System,
    - click the down arrow on the Program button and select Program All Required Data (Slower),
    - exit from the tab and exit from S&T.
    Also, using V8 Scan & Tune, do the same on the Devices tab (filename is Settings.dat).
  9. #19
    Aug 2011
    I did the firmware through hapi and it is current. I just tried the 2nd half of your instructions and still getting script error.
  10. #20
    Can you post your Options.txt file here.
  1. Error $050b
    By minytrker in forum AutoCal
    Last Post: April 19th, 2012, 05:51 AM
  2. Error $050B on V2 BBF
    By Gregs in forum FlashScan V2
    Last Post: March 19th, 2011, 03:24 PM
  3. Newbie with $050B Error
    By razorback_jd in forum AutoCal
    Last Post: February 27th, 2011, 10:00 AM
  4. error code $050B
    By hawaiianstyle in forum AutoCal
    Last Post: January 28th, 2011, 10:53 AM
  5. $050B Error message
    By jennett_c in forum FlashScan V2 BB Logging
    Last Post: July 28th, 2010, 06:37 PM
