Hello Paul,
I had to change the scanning method from Dynamic to Stream Fast in order to get data spit over 5500rpms. The bad thing is that i only get 6-7fps.
Chris
Hello Paul,
Chris
I don't know if others have seen that, but the E40 uses the old 68000 based CPU, not the E38's PowerPC, maybe it's struggling to keep up?
Could be... i loaded less parameters and changed from stream-fast to dynamic...
I need to do some more logging with less parameters in stream fast.
I would have thought they were a better ECU than the ls1.
Well, they both use a 24x reluctor...but still...
