Page 3 of 3 FirstFirst 123
Results 21 to 26 of 26
Thread: Parameters changed for performance.
  1. #21
    I should say "drive pressure" instead of just back pressure. My bad. Drive pressure is between the turbo and engine (technically back pressure) and is a necessary evil to make boost. How much evil is another story. A better flowing exhuast helps to a point.
    Bobo is right, a larger VVT would help out a lot here.
  2. #22
    Quote Originally Posted by Fingers
    Pardon my ignorance....do larger ones exist?, VVT seems like a good thing to me.
  3. #23
    Redline Motorsports
    Guest
    Does anyone make a nice replacement turbo for these trucks without major modifications? Now that the tuning is available, it would be much easier to go to a slightly larger turbo.
  4. #24
    Lifetime Member bobo's Avatar
    Nov 2005
    IMHO: BD turbo is your best shot. It isn't a VVT, but there isn't a bigger VVT out on the market than stock. McRat tried the new LBZ VVT on his 05 LLY. He didn't notice much more than the stock LLY turbo. You could also look into the Aurora 2000 or 5000. The 2000 is just a bit bigger than the stock LB7 turbo, but don't flow as much air as the BD. The 5000 is the big boy of the bunch, but requires head studs, injectors, and possibly CP3 modifications. Tomack runs the 5000. He is putting down around 600-650rwhp on fuel only (12 flat at 7000# in the 1/4). I'm sure the BD is good for 600rwhp(I seen an LB7 run three 13.3 passes w/ 2.0 60ft times on a hot juice alone w/ BD turbo installed) and the 2000 is good for 550. Bang for the buck the BD takes it hands down. ATS is introducing the hybrid VNT (Variable Nozzle Turbo). This has not been proved and is a new engineering concept that has finally been released to the public. I would not mess w/ it yet. I'll let the "twins" folk explain your options there. They are having very good results on the LLY w/ twins.
    2005 Twin Turbo Dmax/Allison Ext. Cab Short Box 4X4
    Best 1/4 11.8 @ 118+ on #2 only
    Twisted Diesel Tuning-The leader in Duramax Tuning Services and soon to offer Common Rail Cummins Tuning!
    Bobotune at rocketmail dot com
  5. #25
    Redline Motorsports
    Guest
    Quote Originally Posted by bobo
    Thanks for this info! I am not looking to go nuts its still a "daily driver". My Corvettes feed my speed appetite! I was hoping there was a nice replacemenet turbo to step it up a bit. Now that the tuning is here, and working, I am kind of interested in fooling around with the truck. I'll look into the options you noted. I have already gone 14.60 in my 4wd crew cab which I though was funny as hell for a 7000 lb truck!
  6. #26
    Nothing bigger right now, but I am working on that. These turbos share some parts with others and function the same from a controls point of view to almost any VVT.
    VVT can be, and is, very effective in other applications. However, to take full advantage, we need some logic changes to the OS.
  1. Changed PCM having VAT issues.
    By vmax in forum Duramax LB7
    Last Post: August 16th, 2009, 02:14 PM
  2. Changed to LS2 90mm on LS6
    By Rusty in forum Gen III V8 Specific
    Last Post: April 12th, 2009, 01:57 PM
  3. What can be changed in the TCM?
    By THEFERMANATOR in forum Allison 5 & 6 Speed
    Last Post: March 24th, 2009, 03:38 PM
  4. Changed my IFR...AFR Is erratic
    By zapp168 in forum General (Petrol, Gas, Ethanol)
    Last Post: August 8th, 2007, 05:19 AM
  5. IAC Changed after TB ported???
    By Ladyredhawk in forum General (Petrol, Gas, Ethanol)
    Last Post: January 25th, 2005, 01:04 PM
