Use:
Start =>Programs => EFILive => V7.5 => Tools => USB Manager to uninstall and re-install the USB drivers. Try the old version fisrst and if that doesn't work, try the new version.
I always unplug the V2 before uninstalling the drivers.
Ira
When you get to USB Manager, right click on it and choose "Run as Administrator"
Ira
Thank you, that worked. I'm still getting error codes opening the programs & I can't register through Help => Register EFILive...
Without knowing the error codes, we can't help you. What does I can't register mean?
Ira
Here's what I get when I try to open V8.
I never had a problem with the programs or playing with stock tunes from the web until tonight when I wanted to pull my stock tune. Took everything out of the box & following the EFILive Dodge Cummins Quick Start PDF hooked it up like it said. As soon as I plugged the V2 into the USB port my computer went to some black screen & said something about error & dumping something.
All I know is I have over $1600 in a laptop & EFILive & I can't get it to work & have no one anywhere near me that I know of that can help me out. I send Rich a message on here asking if I could make the 6.5hr drive down to his shop for him to help me but haven't heard back yet.
I find Windows 7 can sometimes cause issues when loading the software. When you download the software from the EFILive website choose the "Save" option NOT the "Run" option.
These should download to C:\Documents\Downloads ... after the downloads are complete, go to this folder - there should be 2 files there - one for V7.5 the other for V8. Select V7.5 - right click and choose "Run as Administrator" - the software will then load. Repeat for V8.
I'm running the software on both Vista and Windows 7 platforms ... Windows 7 seems a little more "specific" on how it wants to load the programs.
Hope this helps.
Regards,
Taz
