Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: LS1 PCM on a 96 LT1 turbo motor.
    Nov 2007
    Default LS1 PCM on a 96 LT1 turbo motor.
    I've got a built LT1 383 with a TC78 turbo and EFI connections LS1 PCM. It runs with the stock LS1 computer tune, but not very well. I'm getting it tuned on Monday and was wondering if there is anyone who has done this and if they would share some tips. Here are the specs to my build.
    Cam specs.
    224/224 .577/.582 114 LSA
    This is the MAF I'm using, but mine is all aluminum. It has the IAT sensor built in. This website has tables for tuning,
    http://www.powrmax.com/PowrMAF%20100.html
    I don't know what boost I'll be at, anywhere from 10-15psi from what I'm told. I'm not looking for a particular hp or ET or boost level, so whatever springs I'm using now will be fine for a while.
    I'm using a LT1 style monoblade throttle body with the LT1 style IAC and TPS sensors. I have a 3 bar MAP sensor.
    I have an adjustable fuel pressure regulator set to about 42 psi at idle. Twin in-tank walbro 255lph fuel pumps, one set to come on at about 5-6 psi. Fuel injectors are Siemen Deka 80lb high impedance injectors.
    Ignition is a LSI PCM with D585 truck coils (lower dwell time) and MSD wires with iridium spark plugs gapped at .031"
    Rockers are crower 1.65.
    Springs are Comp 26094-16. Seat load: 178lbs @1.900''_Open load: 459lbs @1.275_Rate: 449lbs/in
    I'm using LS7 lifter with about .00416" preload.
    Fans are Flex Lite 410's.
    Tranny is a built 4L60E with a 2800 stall.
    Rear end is a 12 bolt with 4.11 gears.
    Compression ratio should be around 9.2:1.
    General Engine Specs
    1997 .030" over 350 LT1 out of a Pontiac Firebird
    230cc Brodix LT1 Cylinder Heads w/62cc Chambers
    Fully CNC ported intake/exhaust/combustion chambers
    Cometic "MLS" Head Gaskets
    ARP Undercut Head and Main Studs
    CP Pistons & Pins - 24cc Dish (Approx. 9.0:1 comp ratio with 62cc heads and .040 gasket)
    Total Seal Piston Rings
    Manley 5.700" H-Beam Connecting Rods
    Callies Billet Steel Splayed 4 Bolt Main Bearing Caps
    Callies "Stealth" 4340 3.75" Stroke Crankshaft - Internally Balanced
    Fluidampr 7.5 o.d. internal balance 740101
    Cloyes Double Roller Timing Chain
    Canton Road Race Oil Pan, Melling High Volume (10%) Pump Mel-10552, and Canton Pickup
    Trickflow 7.3" Chromemoly One Piece Pushrods TFS-21407300
    Tune the MAF by applying wideband correction.
    Measure rail pressure with reference temporarily removed, and then calculate the IFR (should be flat).
    If you use a COS, make the 105 kPa columns of both VE tables the same.
    If you use a COS, remember to edit the OLFA table, and fix any out-of-range tables before tuning.
    Let us know how it goes.
    Nov 2007
    Thank you. The PCM I have in the car is from a manual and I have a 4L60E, will it still work? I noticed when I took it for a drive, it didn't shift right and the speedo and tach were all screwy, but I'm sure some of that is from my 2800 stall and 4.11 gears. Do I need a COS to fix this issue? If anyone has any more useful tips, I'd appreciate it as it's going to be a long day of tuning tomorrow. Thanks again. I'll forward this to my tuner so he can get a head start tonight.
    Aug 2010
    I take it you are using one of EFI Connections 24x crank reluctor wheels ?
    You will need to flash the PCM with a tune from an automatic transmission vehicle (or swap in the segments).
    What OS are you using ?
    Regards,
    Taz
    Nov 2007
    I'm using EFI Connections 24x reluctor wheel and the OS on the tune I pulled from the computer is 12202088. I haven't touched anything with the PCM yet.
    I do have a tune from an auto 2002 camaro OS 12212156. So I need to flash this tune into the PCM and then go from there?
    Yes as Taz said you need the 4L60E trans segment.
    You could copy all your tables to the 1221215 auto trans file, and then full flash this into the PCM.
    12212156 opens the door to upgrade to COS3/02020003 or COS5/02020005, both of these have boost fuel/spark tables.
    [ with your current 12202088 file, you have to find a matching 4L60E trans segment, and have COS3 as the only upgrade ]
    Aug 2010
    EFI Connection has tunes available for download in EFILive format ... if memory serves they have a 2002 Camaro with 4L60 ... these tunes have had the injector banks altered to work with Gen I firing order ... would reccommend this as a "base" tune for your project.
    Regards,
    Taz
    Nov 2007
    Were sitting here trying to figure this out. Found out the hard way that Windows Vista doesn't like to cooperate with EFI Live, or maybe it was just cause we needed to reboot the system, IDK either way we are using XP now. We loaded the COS 0202005 into it followed by a 2002 Auto Camaro tune. EFI connection switches the wires around in the harness to compensate for the different firing order of the LTX.
    So I have a 3 bar MAP sensor and was wanting to use the MAF for obvious reasons, but it seems we can't. Is there a way to do this?
    Nov 2007
    Thank you guys again for the help.
    Depending on your computer, Vista and W7 might need to run EFILive as Administrators. Go into the Program Files [(x86) if 64 bit OS]\EFILive\V7.5 and right click the Scan executable and the Tune executable. Click compatibility, then click Run as Administrator. Repeat for the other V8 executables as well.
    You should be just fine using a 3Bar MAP and a MAF, the only reason you couldnt use a MAF is if you're moving more than 512g/s of air through it and maxing it out.
  1. Carbureted LT1 Runs on LS1 PCM
    Last Post: May 15th, 2014, 05:22 AM
  2. 06 Turbo LL8 Motor swap into a 240sx Preswap questions.
    By All4bspinnin in forum IL6,IL5,IL4 Atlas Engines - P12 PCM
    Last Post: December 3rd, 2010, 05:01 PM
  3. EFI Connection "24x" System and LS1 PCM for LT1/LT4 Engines
    Last Post: May 26th, 2009, 01:54 PM
  4. lt1 runs on ls1 computer using modded OPTI
    By akafred in forum Gen III V8 Specific
    Last Post: December 29th, 2008, 01:40 PM
  5. Lt1 => Ls1?
    By Cougar281 in forum Gen III V8 Specific
    Last Post: August 9th, 2007, 01:29 PM
