Results 1 to 7 of 7
Thread: Guts Kit Install?
    Default Guts Kit Install?
    I am doing a guts kit install. Should I document it carefully for a tutorial? Or is there just that little demand?
    Doing it on a 3800 PCM (the second RR in a 3800 that Craig and I know of....)
    Jul 2004
    I did one once. No desire to do a second! I doubt there's many people with the tools or ability. It's a 40 pin surface mount chip you need to remove and replace. Anyone who's comfortable with that idea probably doesn't need a tutorial. Of course it might just be interesting for people to see the process.
    Ira
    I do smd work almost daily. So no biggie. But agreed, if you know how to do it, tutorial isn't needed... It isn't for the person who doesn't do this sorta thing a lot. You can do a lot of damage to the PCM or the header with too much heat.
    Can you just snap a few pics? Id be interested to see, I havent done any work (and dont plan to) on the 3800 PCMs.
    I think I'm on that list too
    Nov 2006
    Quote Originally Posted by N0DIH View Post
    Do it and delete this thread.
    LC-1 WBO2
    The pics will show how ept you are at desoldering
    I'm toying with the idea of installing into a 9624 and running it with TunerCat (lol, I carefully worded that );
    as was said, if a tutorial is needed then a person has no business doing this.
  1. RoadRunner guts kit?
    By s10mods in forum RoadRunner Real-Time PCM Emulator
    Last Post: February 23rd, 2017, 12:47 PM
  2. Guts Kit installation
    By SS2win in forum RoadRunner Real-Time PCM Emulator
    Last Post: March 6th, 2015, 01:41 AM
  3. Who on here makes the PPE lift pump install kit i have been hearing about
    By JOKERGERM in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: October 17th, 2008, 01:28 PM
  4. RR 'Guts KIt' installation???
    By hquick in forum RoadRunner Real-Time PCM Emulator
    Last Post: October 7th, 2008, 01:29 PM
  5. Im making a tutorial for the Roadrunner guts kit install today.
    By wait4me in forum RoadRunner Real-Time PCM Emulator
    Last Post: October 5th, 2008, 05:33 PM
