I want to understand my current injector's duty cycle. how do i monitor this???
I have searched to no avail.
RPM and IPW is all you need. the rest is math. no need to scan for it (read: waste your bandwidth), if you can just do a custom PID for it.
Thanks...
And which thread is waste your bandwidth. I cant find it....
IDC, you can scan for it, but that most likely uses up bandwidth (I don't have the software in front of me, cant verify it), unless the default IDC PID is a calculation itself. If that's case please ignore me, and thank EfiLive crew on doing things right
Which year/model/vehicle do you have...?
If it has an LS1 (Gen III) PCM, then you need these specific pids: RPM, IBPW1/2 and INJDC1/2.
Thanks Joe. I do have an LS1B PCM. I have added IBPW1/2 and INJDC1/2 in my V7 fields to populate in my scan.
