Results 1 to 9 of 9
Thread: Problems with Cable.
    Sep 2005
    Default Problems with Cable.
    Recently I have been programming often with my flashcan V1. Just today I started getting the error code no_cable/31 when I try to connect. When I plug the usb, the computer acknowledges the USB with the tinkle sound but I cannot connect to either the scanning or tuning software. On the cable the green and yellow lights are flashing. Help Please!
    2002 GMC Sierra ECSB
    Turbonetics T7675 6lbs boost, 42lb injectors, Single 4 inch exhaust with Hi-Flow Cats, 6.0 swap, Comp Cam LS9 Cam, EFIlive Tune, E-fans, Snow Performance Meth Kit, soon to add KB Boost a Pump,
    Hi JB,
    Did you recently update your software...?
    Oct 2004
    Do you see the device appear, and shown as a FlashScan FSP, in Device Manager?
    Andrew
    EFILive Crew
    Sep 2005
    No I did not recently update my software - everything was working fine then all of a sudden the software does not recognize the cable on both the scan and tune - I have to tune the idling for a new throttle body so Im desperate.
    Sep 2005
    I think it reads it as some kind of usb device but not efilive anymore. I'll have to check again tomorrow as the cable is in the car.
    Oct 2004
    In some rare conditions the USB chip can lose it's configuration. See this article and see if it helps. The MProg application has been replaced with the new FT_Prog application, but it's pretty much the same.
    Andrew
    EFILive Crew
    Sep 2005
    Ok, I'll check that out tomorrow. Thanks
    Sep 2005
    I followed your instruction using Mprog and probelm solved - Thanks Again
    Oct 2004
    Thanks for the update, and glad it worked
    Andrew
    EFILive Crew
  1. EFILive V4 EVAL and ALDL - USB cable problems.
    By Daniele84 in forum EFILive V4
    Last Post: March 25th, 2011, 12:45 PM
  2. DIY cable problems
    By aliman in forum EFILive V4
    Last Post: November 28th, 2010, 10:13 AM
  3. Flash Scan box to usb cable connection problems
    By cmitchell17 in forum FlashScan V1
    Last Post: July 3rd, 2009, 04:17 AM
  4. why do I have a com cable and what to do now?
    By C5Vette in forum FlashScan V2
    Last Post: July 4th, 2008, 11:14 AM
