Results 1 to 5 of 5
Thread: is B9021 available for OS 12587603?
    Jan 2007
    Default is B9021 available for OS 12587603?
    I have been doing alot of reading up on how to get my Min Pulse width down. It appears from all the threads i read that B9021 is the answer. Is this available for my OS? It seems i have only found the files available for the 99-2002 ls1s...
    Thanks in advance for your help
    These are the only ones I have (12202088, 12212156), see attached (these are unmerged, they would need to be added to the other TF cax files).
    Jan 2007
    ya, i have found those CAX files in my searching. I was hoping they could be found for the 1mb PCMs or have the EFI Live guys add them to the standard builds, but it appears no one is supporting/updating the older models...
    B9021 was found by a someone (a user) poking around in memory using trial/error which is time consuming, each OS will have a different address, and some OS's may not have it.
    Jan 2007
    Yep i believe Mick found it. I had Paul create me a bin file from my stock tune and I have PMed Mick about it and he has shown me how to look at the raw bin files with tunerpro, however I have not been able to find a memory map for my tune or for any 1mb PCM... Sooooo, i don't know if it can be accomplished or not since i will be basically starting from scratch with the memory map... I have found a few tools and utilities online to help decipher but it may just be a wash....
  1. 12587603.pdf file
    By cyipher in forum Gen III V8 Specific
    Last Post: September 8th, 2011, 12:47 PM
  2. b9021
    By drdarthinvader in forum Gen III V8 Specific
    Last Post: September 19th, 2010, 01:22 PM
  3. 12587603 os for a flex fuel option
    By chevy052500hd in forum CAX Files
    Last Post: October 2nd, 2008, 01:47 PM
