Page 17 of 21 FirstFirst ... 71516171819 ... LastLast
Results 161 to 170 of 202
Thread: options request : post your ideas
  1. #161
    Ha my CS classes wanted us to use Crimson Editor, hasnt been updated in 5+ years now and the project is dead. Switched to Notepad++ 2 years ago, really like its versatility.
  2. #162
    Allow the engine oil pressure calc pid to show up for Camaro/Firebird (so we don't have to artificially enter a Corvette VIN).
  3. #163
    Scantool chart data highlighting/selection -> Tunetool table cells highlighting
    currrently this has a limit of 100 frames
    can this be made a user option (to select how many frames) (the user is responsible for any slowdown resulting from setting this to greater than 100);
    can there be other options, such as highlight the table cells where the local maximum/minimum occur in the highlighted/selected chart portion (rather than highlighting cells from just the first 100 frames);
    other options regarding this that I have not yet thought about... i.e. that you may have.
  4. #164
    Nov 2006
    Can we add the tool bar options to the conversions tab?
    Linear Fill, Smoothing or user defined custom labels.
    LC-1 WBO2
  5. #165
    Jan 2007
    Can we see about adding B9021 minimum transient p/w.......(Minimum injector pulsewidth during transient conditions
    This table has been shown to limit the minimum pulsewidth in some operating systems.) or it's equivalent parameter to the 1mb PCMs???? My OS is 12587603 and i would like to have this option. Or could it be added to the corresponding COS3????
    Corey
  6. #166
    May 2008
    After doing some black box logging and opening the log in the scan tool, I would like to be able to open a pid file to add calculated pids to my log (Like for calc.ve). It won't let me do this after there is data in the log file.
    2003 Chevy S10 4.3L LU3 LS1B Auto
    48 LB injectors
    Race Proven Motors 2114 intake
    T70 turbo.
  7. #167
    Nov 2006
    You can add calc_pids to a log provided the prerequisite pid(s) were logged.
    They can also be set to open automatically in the V8 software w/BBL.
    LC-1 WBO2
  8. #168
    Like mr.prick said, you can add calc pids after a log was taken (if it contains the prereq. pids), and you can save them into the log.
  9. #169
    May 2008
    Yeah, it's just annoying to have to add like 8 of them, especially since some of them depend on previous calculated pids. I can save the pid file, but can't open the pid file when there's already data in the log.
    48 LB injectors
    T70 turbo.
  10. #170
    Quote Originally Posted by nevinsb View Post
    You can pre-select calculated PIDs for black box logging so that they are already added to the file when you load it into V7.
    See image below...
  1. T43 Ideas
    By oztracktuning in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: February 9th, 2009, 02:12 PM
  2. E67 2.4 LE5 With VVT any Ideas?
    By Quasimotor in forum E37, E38 & E67 PFI ECM's
    Last Post: January 31st, 2008, 11:03 AM
  3. Any ideas up front
    By trudynosports in forum General (Petrol, Gas, Ethanol)
    Last Post: June 11th, 2005, 02:20 AM
