Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: 99 S10 2.2 questions
    May 2010
    I also have a 98 s10 with a 2.2 5 speed. It has a DTS turbo kit on it. Running 15-20 lbs. Forged pistons and eagle rods. It needs a new clutch and slave cylinder, so it has been sitting awhile. I was just wondering if yours was turbocharged, how was the tuning coming along? As they are a pain with this ecm.
    1997 S10, 06 trailblazer SS LS2 swap, 4L70E trans, 76mm turbo. Factory ZQ8 suspension. 3.08, G80 w/a zexel. With a 0411 swap.
    Oct 2011
    Thanks thanks thanks for those uploads.
    gotabav, Im not surprised you're getting a DTC (probably P1481) with efans. Go into System->VATS->Platform Options 1 and change the Electric Fans param to Enabled. Just killing the DTCs doesnt actually stop the PCM from performing the startup diagnostics on the fan clutch, by Enabling this parameter it bypasses the PCMs diagnostics routine and will not throw fan clutch related codes. Works perfectly on my P10 PCM which shares a TON of code with the 4cyl PCMs.
    Junior Member gotabav's Avatar
    Jul 2007
    I appreciate the input for this, but that sin't why it is setting the codes. It has be reflashed with the fan setting enabled and disabled, same codes both times (P1480 and P1481). I tried it again, just in case, same results.
    I haven't messed with this one lately, but I'll probably put the turbo kit together after the holidays and play with it some more.
    2005 Cadillac CTS-V- Forged 383, twin Turbonetics 60-1 hair dryers
    2003 GMC Envoy 5.3-(aka family truckster) bolt ons and tuned
    1999 Chevy S-10-The gutless wonder work truck
    Hmmm, I know for a fact that it works for my P10. Bummer it doesnt work for you, should at least throw some efans on your Envoy though. Good for 10hp and +1mpg!
    Jul 2007
    Oh well, I'm always appreciative of anyone who will give some good advise.
    The Envoy has electric fans on it. I did the modding to that thing before the aftermarket supported it. 3.5 inch cat back exhaust that I welded up from some mandrel bent pipe with a 3 chamber 50 series Flowmaster, 3.5 inch intake pipe with nice filter, e-fans, and a nice tune. It knocks down 24 MPG on the freeway and about 17 in town. This is a 5.3 v-8 not a 6. The best it did stock was 11 in town and 17.6 freeway. Almost 2 MPG just from the fans!
    Jul 2007
    I got tired of trying to sort out the random codes for items that this truck (or any S10) doesn't have. I went back to the stock tune and just played with the VE tables until I got it to run correctly with 42lb. injectors. This may not be the "correct" way to do it, but it works. The truck has run for about 700 miles like this with no drivability problems or any codes set and it knocked down 26 MPG.
    I do have a question about logging on this PCM. It shows odd numbers on the commanded AFR anywhere from .02 to .5, which doesn't make any sense to me. All of my LS1B PCM cars show 14.68, which is what I have the commaned AFR set at in the tune. There is no option for this in my
    P08 tune for this truck.
    Attached are a log and my current tune.Log_0004.efiStock Tune -55%_0002.tun
  1. 2.2 chevy s10 1995
    By turboeds10 in forum IL4, 97-01 PCM and 02+ P11 PCM
    Last Post: July 16th, 2009, 03:03 AM
  2. S10 ZR2 and Tach
    By ZR2_350 in forum Vortec V6/V8 Specific
    Last Post: June 17th, 2009, 06:40 AM
  3. '03 Express van 6.0L in '00 S10
    By Sherk in forum Gen III V8 Specific
    Last Post: June 5th, 2008, 06:46 PM
  4. 99 S10 with 4 banger
    Last Post: June 5th, 2006, 02:18 PM
