Results 11 to 20 of 29
Thread: need B9021 for 01250003
    Lifetime Member BLK02WS6's Avatar
    Jun 2005
    No, some of those tables are at different addresses causing all tables after those to be shifted also.
    Okay, thanks!
    GM EFI Tuner
    02 WS6 9.41 @ 143 MPH 3675#, drag radials, pump gas, through the mufflers - sold
    Oct 2006
    Quote Originally Posted by BLK02WS6 View Post
    Thanks!
    No worries.
    There are three different addresses for B9021 that I have found so far. This makes it easy as it means I only had to write 3 cax files, & you just rename the correct one for your OS & away you go. The list is as follows.
    Cax a
    Stock OS
    12202088
    92111922
    12208322
    Custom OS
    0125000x
    0127000x
    Cax b
    Stock OS
    12209203
    12212156
    12225074
    Custom OS
    0201000x
    0202000x
    0129000x
    Cax c
    Stock OS
    12221588
    12593358
    Custom OS
    0203000x
    0204000x
    The Tremor at AIR
    Cool thanks Mick, narrowing B9021 like that makes it easier.
    Jun 2005
    Thanks - that is awesome!
    GM EFI Tuner
    Lifetime Member MICK's Avatar
    Mar 2005
    Nice work!!!! Great to see the good guys helping out pushing the edge.
    Mick
    Rev it up, Drop the clutch, See what happens?
    Hey MICK, how's it going mate
    Oct 2006
    Cax file updated with 12592618 & 12587603 files.
    The Tremor at AIR
    Jun 2005
    Thanks for working on these 1MB cax files Mick! It is a huge help to some of us! Great job!
    GM EFI Tuner
  9. #19
    Aug 2006
    I'm confused. The first 3 cax files show they are for the same family of OS yet have different Hex addresses for the B9021 parameter???
    1. The 12587603 cax shows it is for a 12202088 OS and a Hex address of C00E.
    2. The 12592618 cax shows it is for a 12202088 OS and a Hex address of BD20.
    3. The cax A shows it is for the 12202088 OS and a Hex address of B630.
    4. The cax B shows it is for the 12209203 OS and a Hex address of B632.
    5. The cax C shows it is for the 12221588 OS and a Hex address of B634.
    Jeff
    98 GMC RCSB 2WD, Internally stock 305 w/Twin T-3 junkyard Turbos,4L80e,Ramjet intake,42lb.inj., 0411PCM, COS3,4675LBS w/me in it. Best Time on 5 passes-13.01@110
  10. #20
    Oct 2006
    Quote Originally Posted by Lextech View Post
    Jeff
    Hi Jeff. I just did not edit the internal descriptions. These have no function at all.
    The Tremor at AIR
  1. is B9021 available for OS 12587603?
    Last Post: November 4th, 2011, 04:39 AM
  2. b9021
    By drdarthinvader in forum Gen III V8 Specific
    Last Post: September 19th, 2010, 01:22 PM
  3. {B3647} in 01250003
    By SS2win in forum General (Petrol, Gas, Ethanol)
    Last Post: August 19th, 2005, 03:32 PM
