I was trying to "read calibration data from PCM". At 8:08 the program locked up and quit running. I left it run for 30 minutes wuth the same results so I stopped the process. Now I get the following and my truck won't start. I have searched the forums to no luck.
11:14:15.646: Scanning for EFILive FlashScan V2 USB
11:14:15.659: Autodetect interface ...
11:14:15.792: Interface firmware version: 2.4.65
11:14:15.794: Connection to [FS2] interface is OK
11:14:15.806: Current protocol set to: "SAE J1850 VPW"
11:14:15.809: Autodetect PCM...
11:14:16.828: PCM not detected.
11:14:16.850: Interface firmware model: FS2
11:14:16.862: Interface firmware model: FS2
11:14:16.873: Interface firmware version: 2.4.65
11:14:16.885: Interface firmware date: Oct 02, 2007
11:14:16.897: FlashScan serial number: 003642847117
11:14:16.909: FlashScan license number: 003642847117
11:14:17.429: Getting status...
11:14:18.004: Status: Calibration missing.
11:14:34.916: Disconnecting ...
11:14:34.957: Disconnected
11:14:35.558: Scanning for EFILive FlashScan V2 USB
11:14:35.573: Autodetect interface ...
11:14:35.691: Interface firmware version: 2.4.65
11:14:35.694: Connection to [FS2] interface is OK
11:14:35.713: Interface firmware model: FS2
11:14:35.725: Interface firmware model: FS2
11:14:35.737: Interface firmware version: 2.4.65
11:14:35.748: Interface firmware date: Oct 02, 2007
11:14:35.760: FlashScan serial number: 003642847117
11:14:35.772: FlashScan license number: 003642847117
11:14:35.785: Disconnecting ...
11:14:35.826: Disconnected
11:14:36.427: Scanning for EFILive FlashScan V2 USB
11:14:36.439: Autodetect interface ...
11:14:36.612: Interface firmware version: 2.4.65
11:14:36.615: Connection to [FS2] interface is OK
11:14:36.627: Current protocol set to: "SAE J1850 VPW"
11:14:36.630: Autodetect PCM...
11:14:37.650: PCM not detected.
11:14:37.669: Interface firmware model: FS2
11:14:37.681: Interface firmware model: FS2
11:14:37.693: Interface firmware version: 2.4.65
11:14:37.704: Interface firmware date: Oct 02, 2007
11:14:37.716: FlashScan serial number: 003642847117
11:14:37.728: FlashScan license number: 003642847117
11:14:38.248: Getting status...
11:14:38.797: Status: Calibration missing.
11:14:45.377: Bootloader version: DLLY_v1.4R (04FC-7BAF)
11:14:45.381: Preparing ECM for reading flash...
11:14:47.410: Autodetect interface ...
11:14:47.444: Interface firmware version: 2.4.65
11:14:47.447: Connection to [FS2] interface is OK
11:14:47.450: Autodetect PCM...
11:14:49.469: PCM not detected.
11:14:50.481: ECM may not be secured - did not reply to seed request
11:14:50.485: Initializing ECM...
11:14:50.488: Initializing ECM, step 1 of 4
11:14:50.491: Initializing ECM, step 2 of 4
11:14:50.494: Initializing ECM, step 3 of 4
11:14:50.497: Initializing ECM, step 4 of 4
11:14:55.508: No response from ECM. Retry 1...
11:14:57.636: Autodetect interface ...
11:14:57.673: Interface firmware version: 2.4.65
11:14:57.676: Connection to [FS2] interface is OK
11:14:57.679: Autodetect PCM...
11:14:59.698: PCM not detected.
11:15:00.710: ECM may not be secured - did not reply to seed request
11:15:00.713: Initializing ECM...
11:15:00.716: Initializing ECM, step 1 of 4
11:15:00.719: Initializing ECM, step 2 of 4
11:15:00.722: Initializing ECM, step 3 of 4
11:15:00.725: Initializing ECM, step 4 of 4
11:15:05.737: No response from ECM. Retry 2...
11:15:05.840: Disconnecting ...
11:15:05.882: Disconnected
11:15:08.418: Done!
Is my PCM wiped clean? When I now try to show calibration details for connected PCm there are no vin #'s or anything anymore. What happened?
Thanks,
Mike
