Results 1 to 10 of 10
Thread: problem with BB logging.
    Jun 2005
    Default problem with BB logging.
    Here it is- I cant seem to log anything.
    I hook up the black box, start vehicle. It shows connectivity. I press recodr/ log button(i dont have it in front of me) and it shows green light. The light goes out after 3-4 seconds.
    So, it looks like it is recording for a few seconds and then shuts off.
    Any ideas?
    Senior Member Wasted Income's Avatar
    Dec 2005
    Did you read the instructions??
    2005 Silverado Duramax LLY - EFI Live Tuned
    1969 Chevrolet C-10 Pickup - Turbocharged 5.3L/4L80E - EFI Live Tuned
    1975 Avenger Jet Boat - 6.0L/Berkley pump - EFI Live tune in progress
    Jun 2005
    Yes. Although I am now going to go back and read them again.
    You have been such a big help.:roll:
    Dec 2005
    http://www.efilive.com/doc/EFILiveV73Scan.pdf
    Did you:
    1.) Validate PIDs?
    2.) Select and program PIDs for black box logging?
    Black box logging is on page 102 of the PDF.
    Is that helpful enough for you?
    Jun 2005
    Sure did. I selected fewer and fewer PIDs thinking that I might have exceeded the max number. Didnt work.
    I will try clearing it and starting over.
    Oct 2004
    After the short logging session are you able to retrieve any logs from the FlashScan unit (i.e. is it actually logging anything)?
    In the FlashScan control panel (page 103 in the scan manual) there is a "Max frames per log:" option. If you set that to 0 it will log till you press the start/stop button again, or the memory fills up. I think by default it logs 600 frames and then stops, so that is only 1 minute at 10 frames per second.
    Hope that helps some...
    Andrew
    EFILive Crew
    Apr 2005
    Quote Originally Posted by Tordne
    That page should be ELECTRIFIED!! I reread the manual 3 times before I caught it [I was smart but I outgrew it]
    Y2K mn6 MY vert
    TI Exhaust, Z06 airlid, EFI grad, kooks headers & x-pipe
    Oct 2005
    Caught me out initially too. You really only get 20min from a session though thats normally enough. I think v2 will let you use memory cards, so you can log forever.. almost..
    2014 VF SV LS3 Maloo.
    Jun 2005
    Im hoping to find time to try this again this weekend.
    Quote Originally Posted by eye-p
    Hey, this is "car stuff", it takes top priority... unless my Mrs. informs me otherwise...
  1. 98 C5 Logging problem
    By TLKSCHP in forum General
    Last Post: May 25th, 2007, 03:35 AM
  2. yet another bb logging problem
    By 2500hd05 in forum Black Box Logging
    Last Post: December 29th, 2006, 09:30 AM
  3. major problem with logging (can't do it)
    By tgeers in forum Black Box Logging
    Last Post: May 18th, 2006, 02:48 PM
  4. Black Box Logging Problem
    Last Post: March 23rd, 2005, 11:53 AM
