Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 42
Thread: Camaro 6.2l Tuning Help
    Senior Member Sid447's Avatar
    Jul 2005
    Smile
    You're going to have a tough time,
    While still using 28lb injectors and a stock fuel pump.
    Both are insufficient for what you have.
    http://www.rceng.com/technical.aspx
    Senior Member DocZ28's Avatar
    Mar 2007
    Quote Originally Posted by Sid447 View Post
    Good Point
    I have 28.8lb injectors. The fuel pump is Walbro 255lb/hr.
    What injectors size I need? The Calculator says 32 lb
    Jul 2005
    Smile
    The 36lb,
    Bosch injectors would be needed.
    Then your time won't be wasted tuning the engine with an insufficient fuel supply system.
    Mar 2007
    The fuel pressure is ok, or it seems ok. I´m getting some hesitation in the range of 1000 to 2000 RPM. I´m not sure if ther is to much fuel or needs mor fuel. It only happen when the engine is not in normal op temp.
    I´m also getting the DTC P0101.
    Change MAF and still the same DTC P0101
    Senior Member Chuck L.'s Avatar
    "The fuel pressure is ok, or it seems ok.".. It's one or the other. That's where the data logging of PSI will help.
    Chuck L.
    CODY Motorsports
    Fuel Injector Service
    Madison, GA.
    706-342-3152
    770-265-5144 [C]
    Mar 2007
    In this moment can be the two scenarios lol. I connect a gauge and reads 59 PSI in low range from 800 to 3000 RPM. I don´t want to test in wot. Cuz More than 4000RPM the O2 goes near .100 mv. And runs like crap.
    Mar 2007
    Just check the FP tutorial, great info.
    Mar 2007
    Finally I have a WB, where to start? Calc VE Tabel, Auto VE, I´m a little confused
  9. #19
    Aug 2010
    Hello Doc,
    You can use either the newer CALC VET tuning method, or the previous AutoVE / AutoMAF combination method. With non-OEM injectors, good results will depend on the accuracy of your injector data.
    Regards,
    Taz
  10. #20
    Start with the Calc VET tutorial, make sure you carefully read the tutorial thread's post #1 and it's summary thread.
  1. Tuning a 2010 Camaro
    By pavetim in forum Gen IV V8 Specific
    Last Post: January 12th, 2011, 02:05 PM
  2. 2010 Camaro tuning
    By GMPX in forum Gen IV V8 Specific
    Last Post: August 1st, 2009, 01:32 PM
  3. what tuning can be done to a stock 98 camaro?
    Last Post: November 5th, 2007, 07:51 PM
  4. Newbie tuning a camaro
    By turbo lcc in forum General (Petrol, Gas, Ethanol)
    Last Post: January 8th, 2007, 03:30 PM
  5. NEED HELP WITH 98 Camaro AUTO VE TUNING
    By Chuck CoW in forum General (Petrol, Gas, Ethanol)
    Last Post: October 12th, 2006, 03:33 PM
