Results 1 to 4 of 4
Thread: Help! Only getting 25% throttle with my DBW Pedal.
    Member Laychut's Avatar
    Jan 2011
    Default Help! Only getting 25% throttle with my DBW Pedal.
    I have hooked up my DBW throttle off a 2005 VZ Calais. I only seem to be able to get 25% throttle which is approx. 2500rpm while in Park. Can I calibrate the pedal with EFI Live? How would I go about it?
    Laychut
    Jan 2011
    Hi All,
    I think I worked it out! The PCM will not let the throttle to open more than 22% unless the trani is in gear and there is load on the power train.
    Currently I do not have my tailshafts connected so there is no load.
    Am I correct or do I still have a problem?
    Laychut
    Jan 2011
    Hi,
    Just thought I would update this thread with how this issue was fixed.
    As it turns out the pinout I had for the pedal connector was incorrect. This was a pinout taken directly from a GM manual.
    Thanks to Doublechip, he had already come across this before and had the correct pinout configuration. Once this was corrected the pedal worked as it should.
    Going places no one else dares to Go!
    60 Series Landcruiser, GenIII LS1 5.7, 4L60E Trans, 4" Stainless Snorkel
    4" Lift, 35 x 12.5 BF Goodrich Mud Terrains
    Thanks for updating.
    Yes, the GM service manual has been known to contain typos... GM do issue errata pages occasionally.
  1. DBW is closing the Blade under hard throttle, HELP!!!
    By JS1965 in forum Gen IV V8 Specific
    Last Post: November 20th, 2012, 03:15 AM
  2. DBW pedal position correlation with throttle body
    By Jim_PA in forum Gen III V8 Specific
    Last Post: October 19th, 2011, 02:56 PM
  3. DBW pedal and TAC module differences
    By DURAtotheMAX in forum Gen III V8 Specific
    Last Post: September 17th, 2009, 06:09 PM
  4. LH6 to LS2 DBW no throttle operation
    By ssvolvo in forum Gen IV V8 Specific
    Last Post: March 23rd, 2008, 10:47 PM
