Hi, this may be a dumb question, but is there a limit on how many times you can flash an PCM?
Laychut
Laychut
I don't remember... I think I calculated you can do 10 flashes per day for 27 years... and and it might still have more life.
It depends on whether the flash chip is rated for 100,000 cycles or 1 million cycles.
If you somehow use all of cycles in the chip I think it is time for a new ECM it owes you nothing.
Sent from my iPhone 4S
2008 2500HD 4X4 LTZ Z71 6.6L LMM
Mods: EFILive, MBRP 4" DPF Delete, BD Manifold, SD Manifold, SD Center Link, SD Sleeves, S&B Intake, FS-2500, PPE Trans Pan, Bushwacker fender flares, PPE Oil Centrifuge, And other non-go-fast things.
Things still need to put in: PCV Re-Route,Air Dog AD-200.
