Page 3 of 6 FirstFirst 12345 ... LastLast
Results 21 to 30 of 53
Thread: Evaporative purge system not ready
  1. #21
    Mar 2005
    Default Need to smog and 02, Catalyst and Secondary Air keep coming up incomplete
    I've got what I think are all the right enablers and every time I come in to have them check, those three keep coming up "Incomplete". All time's I've driven over 50miles prior to checking and the last two had 100miles logged prior to getting checked.
    All the sensors are in place except for the MAF & 02's after the cats, which have the sims. Am I missing something?
  2. #22
    Mar 2005
    I've seen the other "Emissions" posts and similar to this one:
    http://forum.efilive.com/showthread....&highlight=SRT
    Since I actually took the time to put mine back, mine are all set to Trip, Emissions Related with MIL. Does it need to to be set to Not Reported on C6001? I'll go through the actual drive cycle process and see how it goes....
  3. #23
    Mar 2005
    FYI, After blowing another tank of gas without getting SRT ready, I changed relative enablers to Not Reported and that did the trick!! It is mandatory if you want to save gas money..
  4. #24
    Mar 2005
    Thanks Joe
    Just in case someone else runs into the same situation..
    to get the O2 sensors "ready", in addition, I had to set the following to "Not Reported" as well:
    P0134, P0140, P0156, P0160
    And.... for OFF ROAD USE ONLY, of course.
  6. #26
    This is for offroad non-smog usage only.
  7. #27
    ForcedC5, I merged your thread into this one so the info is all in one place.
  8. #28
    For your off-road vehicle, see post #9 above.
  9. #29
    I'll have to look up the DTC's for 2007 C6 Z06 when I get a chance...
  10. #30
    Ok, this is what the service manual pulled up, see attached.
  1. 98-99 pcm swap ? 69 brown evap purge
    By Adam Calley in forum General (Petrol, Gas, Ethanol)
    Last Post: January 9th, 2008, 04:51 AM
  2. LTFT under high manifold vacuum & EVAP Purge
    By vettenuts in forum General (Petrol, Gas, Ethanol)
    Last Post: July 25th, 2006, 10:10 PM
