I am not 100% sure but I believe in some situations the HPT software automatically locks the controller. You will probably need to get it unlocked by the person and/or HPT software that did the tune.
The V8 PIDs have slightly different names, the list of changes is shown below.
Also, All PIDs that in V7 ended with _DMA that are not on this list now end with just _M in V8.
There is an option in the V7 software to "Edit->Copy PIDs for export to V8". So you can highlight all the PIDs in a V7 PID list and select "Edit->Copy PIDs for export to V8".
Than go into the V8 software and right click the green section in the BBL setup window and select Paste. That will perform the PID name conversions automatically for you.
Note: that process does not support calculated PID names.
Code:
#BBL Name V7 name
SAE SAE
WO2AS11 WO2S11_B
WO2AS12 WO2S12_B
WO2AS13 WO2S13_B
WO2AS14 WO2S14_B
WO2AS21 WO2S21_B
WO2AS22 WO2S22_B
WO2AS23 WO2S23_B
WO2AS24 WO2S24_B
EQ_RAT LAMBDA
GM GM
ESTDIAG STATE14
ETCTAC1 STATE15
ETCTAC2 STATE16
ETST ETCS
MAF_GM MAF
MAPS MAP
ACHPRS ACP
GENFDC ALT-F
TP_A TP
FRPS FPS
BBVPS BBS
DESTQ DESTRQ
EOP EOPS
EGRCMD EGRCOM
TRACTRQ ACTTRQ
TTQRET SEMRET
BARO_B BARO
EOLIFE EOL
RUNTIME RUN_TIME
MAFSD DYNAIR_LS2
EGRCLOSE EGRPINTLE
IDLERPM IDLRPM
STFTAVG1 SHRTFTAVG1
LTFTAVG1 LONGFTAVG1
STFTAVG2 SHRTFTAVG2
MFFAIL1 MFFAIL
MFPASS1 MFPASS
LTFTAVG2 LONGFTAVG2
FTV FTP
CASE CASEERR
CURRCYL CKREFCYL
FANDC FANPWMDC
GENLDC GENL_DC
IGN1CC IGNCOIL1
IGN2CC IGNCOIL2
IGN3CC IGNCOIL3
IGN4CC IGNCOIL4
IGN5CC IGNCOIL5
IGN6CC IGNCOIL6
IGN7CC IGNCOIL7
IGN8CC IGNCOIL8
INJ1CC INJECTOR1
INJ2CC INJECTOR2
INJ3CC INJECTOR3
INJ4CC INJECTOR4
INJ5CC INJECTOR5
INJ6CC INJECTOR6
INJ7CC INJECTOR7
INJ8CC INJECTOR8
O2H11DC O2HTRDCB1S1
O2H21DC O2HTRDCB2S1
VSFPDC FPVSPDDC
EOT EOILTS
FANSPD_DES FANSPD_ACT
TSTATE33 TSTATE02
TSTATE34 TSTATE03
TSTATE35 TSTATE04
TSTATE36 TSTATE05
TSTATE37 TSTATE06
TSTATE39 TSTATE07
TSTATE40 TSTATE08
TSTATE41 TSTATE09
TSTATE42 TSTATE10
TSTATE45 TSTATE12
TSTATE03 TSTATE13
TSTATE04 TSTATE14
TSTATE05 TSTATE15
TSTATE06 TSTATE16
TSTATE07 TSTATE17
TSTATE16 TSTATE18
TSTATE02 TSTATE52
TSTATE08 TSTATE58
TSTATE09 TSTATE59
TSTATE10 TSTATE60
TSTATE11 TSTATE61
TSTATE14 TSTATE64
TSTATE15 TSTATE65
TSTATE17 TSTATE67
TSTATE19 TSTATE69
TCMPSLIP TCSLIP
FUEL_MAIN_M FUELQ_MAIN_DMA
FUEL_THR_M FUELQ_THR_DMA
DSP5_VOLT_M DSP5_VOLTS_DMA
SCALCORVE_M SCALEDCORVE_DMA
SCALUNCVE_M SCALEDUNVE_DMA
TRQCALC_M TORQUECALC_DMA
TRQRED_M TORQUERED_DMA
IAC_SD_M IAC_STD_DMA
IAC_SPN_M IAC_STPN_DMA
IAC_SDAC_M IAC_STDAC_DMA
IAC_SPNAC_M IAC_STPNAC_DMA
IAC_LD_M IAC_LTD_DMA
IAC_LPN_M IAC_LTPN_DMA
IAC_LPNAC_M IAC_LTDAC_DMA
IAC_LDAC_M IAC_LTPNAC_DMA
IAC_FRIC_M IAC_FRICTION_DMA
