Results 1 to 10 of 12
Thread: DURAMAX lly Boost tables
    Default DURAMAX lly Boost tables
    What boost tables should be change to get more boost and at what percent should it be change?
    Lifetime Member bobo's Avatar
    Nov 2005
    Before changing the boost levels, you must turn off the EGR. Here is what ya do:
    Set B1502 to 0. Set B1503 to 8000. The EGR will never come on. You also need to set the DTC'S Processing Enablers to X: Not Reported for P0401,p0403,p0404,p0405,and p0406. This will eliminate the EGR test at start up that could set a code from shutting the EGR off or having too much boost during the startup test. Doing these few tasks will completely disable the EGR. EGR will remain closed at all times. You can log it to prove it to yourself also. You need to select the desired pid (an EGR pid) and record the data. Adding an EGR blocker plate will help higher boost from cracking the egr open and is recommended before modding the boost tables.
    2005 Twin Turbo Dmax/Allison Ext. Cab Short Box 4X4
    Best 1/4 11.8 @ 118+ on #2 only
    Twisted Diesel Tuning-The leader in Duramax Tuning Services and soon to offer Common Rail Cummins Tuning!
    Bobotune at rocketmail dot com
    lakingslayer
    Guest
    And be careful. You can get turbo bark if you are a little too aggressive even with the EGR defeated and blocked.
    EFILive Reseller
    Nov 2005
    Setting B1503 to a point above 4,000RPM and setting C2401 to disable is all you need to do. Blocker plate for insurance is optional. Set up this way, the EGR wil not attempt to run, or test so it will not code. I set both 1502 and 1503 to 4100 and the min/max ECT to -40 for good measures.
    www.kennedydiesel.com
    Specializing in Duramax Performance
    More than just a salesman-I use and test the products that I sell on a daily basis.
    Superflow Lie Detector in house
    My dad has a Duramax and keeps talking about buying a tuner. I see EFILive works with Duramax now and I am wondering how much of a gain can we expect from the changes above?
    Most tuners claim in the range of 50-150 and I think he wants like 75-100 if possible.
    Lifetime Member Max Power's Avatar
    Nov 2005
    You are only limited by your tuning ability. 75-100 is no problem. I am making a little over 200 over stock with EFI live at the moment. Hopefully I can figure out how to make more.
    09 LMM Duramax
    Dec 2005
    Which tables are you modifing to change the Boost?
    lakingslayer
    Guest
    Quote Originally Posted by turbo lcc
    B2205,B2206,B2208,B2209. Depending what your Baro readings are you probably won't need tables B2205 and B2208. I do them anyway just in case.
    Junior Member 02gmcwaldoch's Avatar
    Which table would I modify if the barometric pressure were at 11.6? How would i modify the table just increase it across the board or just in certain RPM's? How high can i go on the #'s?
    JESSE
    Nov 2005
    Quote Originally Posted by 02gmcwaldoch
    JESSE
    Do you have a boost gauge? Pyro?
  1. Boost fueling tables
    By limited cv8r in forum Custom Operating Systems
    Last Post: March 17th, 2009, 05:17 PM
  2. lbz boost tables
    By dynarex in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: March 28th, 2007, 02:54 PM
  3. ECT Boost tables inop
    By killerbee in forum Duramax LLY
    Last Post: February 17th, 2007, 01:24 PM
  4. Boost Tables info?? - EGR on/off
    By turbo lcc in forum Duramax LLY
    Last Post: March 19th, 2006, 05:23 AM
  5. Boost tables - mm3 per stroke?
    By turbo lcc in forum General (Diesel)
    Last Post: March 14th, 2006, 03:03 PM
