Page 8 of 8 FirstFirst ... 678
Results 71 to 80 of 80
Thread: Release Candidate 8, Jan 06, 2012
  1. #71
    Its in there when you select Innovate! I completely ignored it because there wasnt an option, honestly I had no idea this was implemented until Simon mentioned it because I only have 1 WB.
    Sorry, yes you're correct, it is in the Edit Settings option on board FlashScan even if Innovate is selected (however it is ignored when computing AFR when Innovate is selected).
    It is not available in the V8 software Device Settings option when you have Innovate selected.
  2. #72
    May 2009
    Cummins 5.9 "timing coolant temp multiplier" ECT axis points and first column values change after closing and opening with tune tool
  3. #73
    Quote Originally Posted by cumminsDK View Post
    Do you mean they change by a very small amount? That will be because of the rounding errors when data is converted between integer storage in the ECM and floating point values for display on the screen.
  4. #74
    Mar 2007
    For some reason I cannot retrieve the Log file from V2 or autocal EE shows no file?? . I see I should up date the Script files... how do i do that??
  5. #75
    May 2009
    No I mean drastic change I set axis values top to bottom as follows -20 -10 0 10 20 and so on it might stay our it might change to and this is what happens most of the time, 64 at top decreasing to zero then back up to 64 at the bottom, and first column I set top 4 cells to 1.00 and they change to .2 up to .8 I think
  6. #76
    Quote Originally Posted by Harrismarine View Post
    Which V8 build version...?
    Did you terminate logging by pressing the On/Off button on V2/AC...?
    In EE, on the Scan tab what do you see...?
  7. #77
    HiJoe,
    I'm pretty sure that issue got sorted. Just needed to select the [Scan] folder to see the log files in EFILive Explorer.
  8. #78
    Ah, ok, thanks (I was wondering if he saw the Scan folder).
  9. #79
    Mar 2007
    Thanks for the reply joecar, it was me not clicking on the scan tab in EE. Paul sorted it real quick
  10. #80
    Jun 2011
    Any news when this RC will be commercially available with the ability to disable egr, dpf and all emissions systems? Thanks.
  1. Release Candidate 7, Dec 22, 2011
    Last Post: January 4th, 2012, 07:12 PM
  2. Release Candidate 2, Aug 19, 2011
    Last Post: September 13th, 2011, 09:58 AM
  3. Release Candidate 1, Aug 04, 2011
    Last Post: September 11th, 2011, 03:36 AM
  4. March 05, 2011 release candidate 2
    Last Post: March 20th, 2011, 02:36 PM
