Results 1 to 10 of 19
Thread: E38 Cranking Issues
    Oct 2009
    Default E38 Cranking Issues
    I recently had a fuel system installed on my 2010 Camaro. The main difference is the new fuel system has a return and a pressure regulator after the rails. The issue is when I go to start the car sometimes will crank for a long time before starting. When the engine is cold it cranks immediately. After a 10 minute drive, the car will turn over multiple times and eventually start but takes about 1-2 seconds to start. This did not happen with my current tune prior to the fuel system. I'm not sure where to begin. Any help would be appreciated.
    Dec 2007
    Quote Originally Posted by mirage View Post
    Whats wrong with the stock system?
    Oct 2009
    Quote Originally Posted by gmh308 View Post
    Supercharger making 14 lbs of boost doesn't like stock fuel lines.
    swingtan
    Guest
    Heat soak in the fuel rails? If you prime the fuel system a few times to flush fuel through, does it start easier? You may need to richen up the hot start cells to compensate.
    Simon.
    Oct 2009
    Simon.
    Yes if I turn the key on and let the pump run it does start easier. So which cells should I increase?
    Oct 2009
    The one spot that looks interesting is here: (Notice how the EQ Ratio is lower after the ECT's are warmed up. This would typically be the case, but might be the issue in mine)
Name:	Camaro Fuel EQ Ratio when Cranking.png
    If you changed from a return-less FPR/rail to a return/referenced FPR/rail did you adjust the IFR table...?
    When the FPR is manifold referenced, the IFR table has to be flat.
    The table in post #6 has nothing to do with the poblem.
    Oct 2009
    Hmm.. No I didn't I adjusted for the fuel changes using the VE tables. Here is my B4001 table as it sits today:
Name:	Camaro IFR B4001.png
    swingtan
    Guest
    What's the go with the cranking fuel? I would have thought that the commanded cranking fuel would have been around 12:1 - 14:1 AFR, but your table is indicating 6:1 - 7:1 AFR's. With your description of the hot start, I'd have initially guessed it was a little lean, but not with those AFR's. Unless of course you're running Ethanol or your Stoichiometric setting is set to something other than ULP.
    The only other thing I'd look at is that the SC is probably restricting air flow at low RPM's ( cranking ) so you may want to add 10% to the hot start cells in {B1832}. A quick test there would be to give it a little throttle when cranking to see if it fires easier.
    Simon.
    Oct 2009
    Simon.
    I will continue testing over the next few days and see how it goes. On the cranking commanded fuel, I initially guessed the same thing that you did in that the engine did not have enough fuel to the rails, but after making the adjustments you indicated and the initial results so far I think I will start to bring the cranking command fuel AFRs back to the stock levels and see if starting improves even further. Thanks for your help!
  1. E38 Throttle command cranking?
    By DVR IMP in forum E37, E38 & E67 PFI ECM's
    Last Post: December 2nd, 2011, 05:14 AM
  2. e38 cranking help
    By ringram in forum E37, E38 & E67 PFI ECM's
    Last Post: March 20th, 2010, 01:47 AM
  3. 2 bar E38 issues
    By XLR8NSS in forum E37, E38 & E67 PFI ECM's
    Last Post: May 1st, 2009, 03:51 AM
